I see threads that say Steele has the correct seal for the engine cover lid. Steele has a couple listed but none are specific to the first gen G. Does anyone have a part # or any experience with them? Thanks for the help, Jerry
Doghouse Seal from Steele
65-G10-guy- Number of posts : 110
Registration date : 2012-11-16
Re: Doghouse Seal from Steele
It comes in a roll and you cut to size. Just need to glue it down not as tight as the original. Here is everything you need for seals. This thread will give you everything you need.
https://vintage-vans.forumotion.com/t18627p15-window-seals-and-windshield-seal?highlight=seals
This works perfect and seals tight and is a fraction of Steele's price...has self stick strip and you cut it to length...
http://www.ebay.com/itm/3-45M-x-12mm-x-10mm-D-Shape-Rubber-Seal-Noise-Strip-Weatherstrip-/400495357289?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3f622d69
Thanks, appreciate the help, Jerry
Hey Jbass, do you know if that D-shaped strip will work on Econo Doghouse as well?
diamond dave- Number of posts : 565
I used a cavalier trunk seal, as suggested on here, and It seems to work great. and I got it at a local pull a part yard for 4 bucks. I cant remember how the seal on my econoline was, but, im sure it could be made to fit pretty easily.
Thanks for the info Diamond Dave!
