+57
SteelyVan
Bear
AzDon
mattimuss
whalemstr
LiveWire64
richie61
ditdater
Rick's 66 Chevy Van
Marcosis
Tice84
vern01
66_Barracuda
deepott71
kookykrispy
Vantastic
drc
kaz
64chevy
NipRing
scarlin
JAX
66mnecotruck
SDEconoTruck
61 posters
    Dons day,,,,,,,
    Number of posts : 12246
    Dons day,,,,,,, - Page 17 Empty Re: Dons day,,,,,,,
    Post by donivan65 Wed Mar 09, 2016 3:14 pm
    The floats are set too low,,,,,,,,look where the gas level was,,,,,She just had the carbs rebuilt,,,,,,,gas was not even reaching the accelerator pump wells and the cups are all dried out and cracked,,,,,,so she can order some new pump cups and I will reset the float levels,,,,,,,since I am dealing with old gas,,,,,I pulled out my cycles little brothers,,, the Sachs and Vespa,,,,,,might as well clean out their tanks and carbs,,,,,and its about 80 out right now,,,,,,
    Dons day,,,,,,, - Page 17 03081613
    Dons day,,,,,,, - Page 17 Dscn7819
    Number of posts : 14778
    Post by vanny Wed Mar 09, 2016 4:43 pm
    Glad to see you figured out what was going on...by the way, it hit 70 here today in Massachusetts!!! In March no less. If I didn't have to go to work tomorrow, I'd sleep out on the deck. Great winter compared to last year! Don, what kind of seats are those in your van? They look Nice!
    Post by donivan65 Wed Mar 09, 2016 9:07 pm
    $15 Mazda 626,,,,,,,,,,,,
    Dons day,,,,,,, - Page 17 Repair10
    Post by vanny Thu Mar 10, 2016 3:14 pm
    That's one heck of a Deal! Did you have to modify the width or do they clear the doghouse? Just looking for seating options ...
    Post by donivan65 Fri Mar 11, 2016 11:22 am
    The Chevy doghouse aint in the middle,,,,,its 2" over to the passenger side,,,,,,,,this makes it 22" from the drivers door,  20" from the passenger door,,,,,,,,and the seats sit on the wheelhousing,,,,,so you have to fit seats within those boundaries,,,,,,,,,my seats are 22" ,,,,,,,,so I have to pull in on the passenger cushion to close the doghouse lid,,,,,,,,peoples sure like those 20" Fiero seats with the speakers built into the headrests,,,,,,,so you bolt the seat track to the wheelwell,,,,,,and make some sort of bracket to hold the inner track up,,,,,,,,
    Dons day,,,,,,, - Page 17 Dscn7825
    Number of posts : 2087
    Post by Seth G Fri Mar 11, 2016 12:56 pm
    I got a nice pair of Dodge Neon seats from the yard for mine and need to make some framing like that for them. They look to fit pretty good. Iirc he charged me $20 for the pair. Been putting it off, but I should get after it. My van already had some poorly made frames for some old seats out of something or another I pitched. Not sure how the new seats would align with the oem frames.
    Post by donivan65 Fri Mar 11, 2016 1:39 pm
    ,,,so how much room you got from the doghouse lid to each door,,,,,,and how wide are those Neon Seats?
    Dons day,,,,,,, - Page 17 Seat10
    Post by Seth G Fri Mar 11, 2016 11:43 pm
    Those seats are similar to how the neon seats attach, but they fold down and bolt at 60-90 deg angle at the front end of the rails
    Post by vanny Sat Mar 12, 2016 12:39 pm
    Thanks for the pictures and information guys!
    Number of posts : 698
    Post by Russell Sat Mar 12, 2016 7:29 pm
    I was able to mount my seats to a flat surface I used the stock brackets mounted on the doghouse, one over and one under, and a length of 1x1 under some plywood over the wheelwell side to make up a box to support the seat, storage in the back and speaker mounted in front.
    Dons day,,,,,,, - Page 17 Heater10
    Post by donivan65 Sat Mar 12, 2016 7:35 pm
    That looks kind of high, Russ,,,,,,,,biggest complaint is that the seats are too high and they have to smash the wheelwells down to get the seats lower,,,,,,,do your seats have the adjusters on them also?
    lets see how thick your seats are,,,,,,,
    Post by donivan65 Sun Mar 13, 2016 6:29 pm
    Went over to Surfer J Scotts new place today to help him tear apart the drivers door on his wifes Honda SUV,,,,,,,,,seems to me he took the car to the Honda Dealer for some work and wore out his welcome there,,,,,,,,
    Dons day,,,,,,, - Page 17 03131610
    Dons day,,,,,,, - Page 17 Dscn7828,
    Post by Vanish Sun Mar 13, 2016 7:55 pm
    Honda Element ?????
    Post by Seth G Sun Mar 13, 2016 8:26 pm
    donivan65 wrote:,,,so how much room you got from the doghouse lid to each door,,,,,,and how wide are those Neon Seats?
    The seat's are just over 20" wide. Should fit well.
    Post by donivan65 Sun Mar 13, 2016 9:33 pm
    Dons day,,,,,,, - Page 17 Dscn7911
    Post by Russell Sun Mar 13, 2016 10:21 pm
    donivan65 wrote:That looks kind of high, Russ,,,,,,,,biggest complaint is that the seats are too high and they have to  smash the wheelwells down to get the seats lower,,,,,,,do your seats have the adjusters on them also?
    Check "members showcase""Russell's 65 Chevy Sportvan Deluxe" My seats sit nice, track only on drivers side.
    Post by donivan65 Sun Mar 13, 2016 11:27 pm
    Dons day,,,,,,, - Page 17 Heater12
    Dons day,,,,,,, - Page 17 Heater11
    Post by donivan65 Sun Apr 17, 2016 5:17 pm
    Had me a house guest last week,,,,,,a 1964 Corvan 95,,,,,,,,,,,,,,,,,,,,,,,,
    Dons day,,,,,,, - Page 17 Dscn7916
    Dons day,,,,,,, - Page 17 Dscn7912
    Dons day,,,,,,, - Page 17 Dscn7913
    Dons day,,,,,,, - Page 17 Dscn7914
    Dons day,,,,,,, - Page 17 Dscn7915
    Post by vanny Sun Apr 17, 2016 5:52 pm
    Is that the one that wouldn't stay running?
    Post by donivan65 Sun Apr 17, 2016 7:19 pm
    Thats right,,,,,the accelerator pump cups were dried out and floats set too low,,,,,I just had it for a week,,,,,,to check it out,,,,,,,its missing its heat doors,,,,and since its air cooled,,,,the automatic chokes dont get the right amount of heat and dont act right,,,,and you got 2 carbs,,,need to be balanced and and then adjusted,,,,,I dont know that it has the correct dipstick in it,,,,,,,the shifter shaft is bent,,,,,putting pressure on the seal and it leaks,,,,,,but at least it starts and drove away from my house,,,,,,and thats a good thing,,,,,,,,
    Post by donivan65 Sun Apr 17, 2016 7:53 pm
    I did cruise up to EconoWest 2016,,,,,,,talk about misery,,,,,,,7 hours on the road,,,,,140 miles north of me,,,,,,and you need to drive through Los Angeles to get to Pasadena,,,,60 mile an hour winds through the canyons,,,,,90 degrees outsideDons day,,,,,,, - Page 17 Econow53
    Dons day,,,,,,, - Page 17 Econow54
    ,,,,and GRIDLOCK everywhere you went,,,,,5 MPH on the freeways,,,half hour just to get on them and there you sit,,,,,and EVERY freeway I got on and there are a LOT of them in LA,,,,,,but there were quite a few Vintage-Vanners there,,,,,,me and 64chevy guy were there,,,,,Ugly Larry and 66BC sure were excited to be there,,,,,they rounded up the Chevys for a picture after the Fords and Dodges left,,,,,,,,
    Dons day,,,,,,, - Page 17 Econow56
    Post by vanny Mon Apr 18, 2016 5:44 am
    Nice turnout, glad you had a good time after putting up with all that traffic!!!
    Dons day,,,,,,, - Page 17 Smiley10
    Post by donivan65 Thu Apr 28, 2016 11:03 pm
    ,,,I need to hear some jammin,,,,,,
    Dons day,,,,,,, - Page 17 Th_tom1_zpspz7dbpkt
    And thats the way, uh huh, uh huh,,,,,,,I like my music,,,,,,
    Post by vanny Fri Apr 29, 2016 2:41 pm
    That be some heavy duty jammin, Mon! afro
    Dons day,,,,,,, - Page 17 Jammin10
    Post by donivan65 Fri Apr 29, 2016 3:01 pm
    ,,,and Prince doing While my guitar gently weeps is another favorite of mine,,,,,,
      Current date/time is Mon Nov 18, 2024 1:44 am
