    Lower My Van Dropped Axle 2-3 Inches Garage suggestions?
    greenothedog
    greenothedog
    Number of posts : 3
    Registration date : 2013-12-05
    Lower My Van Dropped Axle 2-3 Inches Garage suggestions? Empty Lower My Van Dropped Axle 2-3 Inches Garage suggestions?
    Post by greenothedog Wed Feb 12, 2014 4:48 pm
    Hi
    does anyone know a good garage in that can lower my van
    dropped axle etc....
    im looking to lower a couple of inched on the ride height
    nostalgia sids sounds like a legend in this department in oklahoma
    he is backed up 2 months of work and doesn't think he can fit me in
    im driving all over the country so
    albuquerque
    dallas
    nashville
    cleveland
    LA etc are all possibilities if you know someone that can 1) do it and 2) fit me in
    the second option is to buy the parts from Sid's and have a go fitting them myself
    Lower My Van Dropped Axle 2-3 Inches Garage suggestions? Empty Re: Lower My Van Dropped Axle 2-3 Inches Garage suggestions?
    Post by Twinpilot001 Thu Feb 13, 2014 12:08 pm
    in the archives=maybe in evan stuff?? this question is addressed before.There is a company that is doing some axles=dropping them up to maybe 6" yet I think 4 is the max???? With standard axles -when bent (dropped) the width changes -badly! so -more problems are made than needed. You can relocate the axle on TOP of the springs -yet ?? search arcives here. Smile
    JD
    JD
    Number of posts : 82
    Registration date : 2013-03-21
    Post by JD Thu Feb 13, 2014 12:43 pm
    I plan to buy the parts from Sid to lower my van.
    Then have Cory aka Wheelie do the work at his shop
    His shop is located about 25 miles north of Dallas.
    JD
    Number of posts : 2198
    Post by EconoUSAparts Thu Feb 13, 2014 2:29 pm
    Axle on top of springs is by far the cheapest way to do it. Using Sid's or Mordrop type axle means it must be disassembled and all new king pins put in. If you need them great, if not it's an extra expense. Total job at least $500.00.
      I believe I posted pics on site somewhere of the blocks I had made up to do my 62. I think mine are much nicer than the method used on the Gearhead Flicks van seen on their video on You Tube or on their site. Mine on my 62 are basically the same as the ones used on my 61 prostreet that Mike Ouellette built. Total cost about $100 with new U bolts.
    That being said, is anyone on here running a drop axle on their early Econoline? One last thing to remember is a stock axle that's dropped (like Sid's) will be about an inch narrower each side when done which *may* cause interference depending on the wheels and tires used on it or it could be a benefit if having clearance issues on certain wheel/tire combinations.
    FCC
    FCC
    Number of posts : 295
    Post by FCC Mon Jun 23, 2014 12:18 pm
    Lower My Van Dropped Axle 2-3 Inches Garage suggestions? Bump-road_sign
    Who's running a drop axle?  Can you post your thoughts, experiences and a pic or two?
      Current date/time is Fri Nov 22, 2024 9:37 pm
