by m1dadio Sun Mar 09, 2014 6:28 pm
Coolant hoses can be higher quality if they are not the cheep "off shore" made junk. I think the gates coolant hose is better then some fuel hose today.
The quality made coolant hoses are made to handle much higher pressure, they are made to handle very much higher temperatures and they are made to resist the fuel and oil (hydrocarbon) deterioration they will get both in an engine compartment and in the coolant itself. and they are en made to handle constant moving and flexing.
Gates OE-style, small diameter hoses are built with a premium quality EPDM tube and cover to assure long service life. The material resists electrochemical degradation that causes tube cracking and unexpected hose failure. Temperature range is -40°F to +257°F.
Ethylene-Propylene –Diene-Monomer, EPDM, materials have long been proven in their excellence for demanding applications; i.e., resistance to aging, weathering, ozone, water, steam and chemicals including acids, alkalis and oxygenated solvents – overall it is the material of choice for various outdoor environments.
Now, combined with the Ultra-Vanshield coextrusion process, an even higher level of performance for RFI-EMI shielding is available. Construction consists of a versatile EDPM core covered with a conductive Silver/EPDM (AgEP) outer jacket. The combined result – abrasion resistance, silicone outgassing eliminated, even Phosgene gas does not deteriorate performance characteristics.
Meets military NBC (Nuclear, Biological and Chemical) specifications.
Should also handle a nuclear blast , I think what you have is probably better then what might have been available back in the 60s.
M1D
