So, I attempted the Ford 3G swap and the alternator I ordered was too big. I couldn't get the proper clearance after the header install. So... I switched to a late 70's GM Van alternator (that someone suggested on this forum, thanks!) I was able to get it to fit with no major hang ups. The only issue I ran into was running the white wire to the Generator light. I hooked the white wire to the yellow/black wire and the light was on constant. When hooked to the black wire, I wasn't able to turn the van off. Everything I've seen online doesn't say anything specific to these vans... I'm sure someone here knows the trick. Any info is appreciated!
GM Alternator swap
Full Tilt Boogie- Number of posts : 44
Registration date : 2011-06-14
