    Alternator swap
    mcVann
    mcVann
    Number of posts : 39
    Registration date : 2013-09-24
    Alternator swap Empty Alternator swap
    Post by mcVann Thu Mar 13, 2014 10:36 am
    Hello everyone.
    I've looked through the archives and haven't seen or may not have seen a swap to a Ford alternator. I see alot of GM swaps into an E' series van.
    is this a cost or efficiency thing? Im going to put a 71 Maverick/Mustang 170 alternator and the resistor from Radio Shack. its about 35$ total.
    why hasn't anybody else done this?
    Number of posts : 12246
    Alternator swap Empty Re: Alternator swap
    Post by donivan65 Thu Mar 13, 2014 11:13 am
    ,,,well,,,,,,a $29 one wire GM Alternator with the voltage regulator built in is way easier to put in than getting an alternator that you need to wire up an external voltage regulator,,,doesnt that Maverick use the same system as a Van with an Alternator?
    mcVann
    mcVann
    Post by mcVann Thu Mar 13, 2014 11:59 am
    dont know, im swapping out the original generator.
    AND wanted to keep it ford.
    Post by donivan65 Thu Mar 13, 2014 1:08 pm
    you surely don't want that generator,,,,,and your Ford vans did come with an Alternator,,,,so you have plenty of choices,,,,,but you need to upgrade your wiring if you put a bigger Alternator on it,,,,,they make some Big output Alternators and some for big money also,,,,,,
      Current date/time is Fri Nov 22, 2024 1:17 am
