ncbkr2002
engine cross member question
ncbkr2002- Number of posts : 140
just wondering IF there is any way to install then engine cross member backwards ?? can it be bolted up either way or is there ONLY one way it will bolt up ???? i put my 350 in and now when i attempted to put my block hugger headers on .... the collectors are hitting part of the cross member. just curious ?? thanks guys .... not sure if i had a brain fart when i put it in
Re: engine cross member question
well=????????????????????u say block hugger headers?? I have them on mine & they dont have collectors!!! u have any pix of urs??made by?? curious if u have a standard v-8 gm mount under thye engine?/ I do.
no pix now .... but they are standard gm mounts ..... not sure who made them as i got them used but they loook exactly like all of the other huggers ive seen ....
that is not my engine just one i saw on this site but exactly what i have
- Number of posts : 12245
I would say the correct 1st Gen crossmembers slant forward,,,,,2nd Gen slant rearward,,,,,,and you can put them both on backwards which moves the engine,,,,,
thats gonna suk if i did cause i just spent $158 to get my driveshaft cut and balanced
This is why you always stamp your parts when disassembling.....
I believe that's a picture of my engine! Bill
i belive so .... did u use collectors on the bottom of those hugger headers ? BILLS66 ?? do u have a pic of the finished exhaust ??
pix oft v=8 is same as mine!! all clears fine.
Joe Van- Moderator 1st Class
- Number of posts : 4619
joe van ..... did you lower youre engine any ?? i lowered mine 2 inches .... not sure if that would even matter ....
- Post n°19
- Post n°20
- Post n°21
- Post n°22
- Post n°23
- Post n°24
- Post n°25
