    First Gen Missing Air Cleaner
    67supervan
    Number of posts : 205
    Registration date : 2011-09-20
    First Gen Missing Air Cleaner Empty First Gen Missing Air Cleaner
    Post by 67supervan Wed Nov 13, 2013 7:42 pm
    Can anyone show me some pictures of what I'm missing in this photo of my 66 chevy six cylinder?  I'd like to put the stock item back in place.  Got one for sale?
    First Gen Missing Air Cleaner Missin10
    First Gen Missing Air Cleaner Empty Re: First Gen Missing Air Cleaner
    Post by G-Man Wed Nov 13, 2013 7:45 pm
    mine not for sale, but will try to get you a pic Thurs. I have a 66 with a 230
    Number of posts : 1412
    Post by Vantasia Thu Nov 14, 2013 6:02 pm
    Do yourself a big favor and get rid of all that loose hanging insulation, it will catch fire and burn your engine up especially if you run it without the air cleaner, one backfire and your done...happened to me many years ago on a '66.  Re-line the cover with modern foil faced heat insulation, many on the market to choose from, try eBay for starters...Get a small 4-inch paper air cleaner from auto store like Pep Boys in the mean time.  A stock air cleaner may be hard to come by, I've asked around and no one is willing to part with one.  You can search junkyards that have older pickups and vans and probably find something similar that would fit, but the modern small ones that sit on the carb are all you need...
    67supervan
    Post by 67supervan Thu Nov 14, 2013 6:50 pm
    Thanks for the info. It'll all be overhauled this year.
    Number of posts : 12246
    Post by donivan65 Thu Nov 14, 2013 6:59 pm
    First Gen Missing Air Cleaner Repair30
    Post by G-Man Fri Nov 15, 2013 8:36 am
    sorry my internet was down Thurs. Heres mine
    First Gen Missing Air Cleaner 00117
    If you find a air cleaner be sure you get the riser for the carb, I may have a extra riser, but see if you can get everything from someone first
    First Gen Missing Air Cleaner 00219
    67supervan
    Post by 67supervan Fri Nov 15, 2013 8:42 am
    So it's 3 pieces of metal plus a pair of mounting bolts with wing nuts?
    -the big round part with the air intake tube
    -the oval part bridging to the carb
    -the riser from the carb
    Post by donivan65 Fri Nov 15, 2013 9:49 am
    First Gen Missing Air Cleaner Repair31
    Dawgboy
    Dawgboy
    Number of posts : 278
    Registration date : 2013-04-20
    Post by Dawgboy Fri Nov 15, 2013 10:17 am
    Ill try to see if it's still there in the Boneyard machine I saw tomorrow. if it is, I'll grab it for you. It was definitely off the engine, but there was a bunch of junk lying in the back.
    Post by Vantasia Fri Nov 15, 2013 11:31 am
    I inquired on this van being parted out, has the air cleaner with all the brackets for $80 +shipping, call them ASAP
    http://www.ebay.com/itm/131038987488?item=131038987488&viewitem=&sspagename=ADME:X:RTQ:MOTORS:1123&vxp=mtr
    67supervan
    Post by 67supervan Fri Nov 15, 2013 1:30 pm
    The 66 van I bought has been intransit until about an hour ago.  To make a long story short, the "lost" air cleaner was located and included - quite a nice surprise after seeing the photo of it missing.  I've been in a rush to replace it because the motor rebuilder I'm taking the van to tomorrow morning said he'd not include a warranty if I didn't have an air cleaner in place when it's driven away.  I was going to resort to buying a small aftermarket assembly if I couldn't find an original in time.  (I wish the seller's photo would have shown the fact the doghouse lid has no locking support bracket.)
    Thank you G-man and Donivan65 for the photos - it's helped me verifiy I've all the correct pieces of metal (I can deal with my missing paint).  And thanks jbass62 and Dawgboy for your info and offers.  It's nice to receive excellent and fast help.
    Post by Vantasia Fri Nov 15, 2013 3:23 pm
    The 64's and most '65's just had a chain to hold the doghouse cover open, I'm not sure when they started with the rod in a slot along side the passenger seat with notches to lock it open, I recall my old '66 had this and no chain. Yours may have had the chain set up, its just two holes, one in the cover and one on the side of the doghouse behind the passenger seat side for a bolt to hold the chain. I used flat link chain from a home center and some 1/4-20 bolts, works fine if you don't have the rod set-up. I just run the small 4-inch air cleaner on top of the carb, seems OK, does the job
    Post by G-Man Fri Nov 15, 2013 6:18 pm
    My 66 had a chain, I put a Econo prop on mine, much better design than the rod
      Current date/time is Mon Nov 18, 2024 2:38 am
