Good morning everyone. I recently purchased a 1963 Falcon camper. It is the one in my profile picture. It has the rounded pop-top on it. The guy I bought it from said it leaked a little around the side door because of a bad door seal. It actually leaks from the camper top. When I look up from below, I can see light around the edges. Something had also slightly dented the camper tops top while in the down position. I don't know if that also contributes. I assume that I need some sort of seal between the roof and pop-up. Yesterday, I was driving along and saw a camper just like mine that had a very thick black seal around the top of the roof and pop-up. It looked very good and I thought it was factory made. When I got back to the office, I did a Google search and couldn't find anything that looked like that seal. Does annyone make a reproduction seal? Is the black one a home-made job? Thanks.
Camper top seal
jupiter8- Number of posts : 14
Registration date : 2013-07-26
Camper top seal
Re: Camper top seal
That seal is just a foam seal - available at any builders supply! Get one that is imprevious to water! Usa a flexible caulk in needed (sparingly) on the opposite side of the seal if needed. You will possibly find after removing the complete top ( best ) to check all wood panels- possibly needing new wood from water & rot?? I know - have 3 tops currently. That top was a conversion done from 1961- 1968 by "Travel Equip. corp." in new jersey-was usually done by them & yet some dealers did that also. Those tops are the easiest to raise & lower & offer great versitility for the vans & camping. There were 3 different types = 2 of which had a different window design & 1 that was used only on dodge vans that was not rounded on the forward end-cut off & flat ended =looked weird to me .replace all the screws / bolts securing the top with stainless & look at the wood thats under the top mounting - as that is a custom made piece yet easily done. That project is best done in summer time or inside a shop / garage in winter. Happy vannin= yes =black seal is homeade one =
steelrat- Number of posts : 116
Registration date : 2014-11-24
Re: Camper top seal
I am about to look for a seal for the camper top. What shape is the one referenced?Is it. Channeled, split or? We do not have Lowes in BC, but have Home Depot. I have not been to HD looking yet, thought a descip would help me.
Thanks
Shaun
Thanks
Shaun
