    65 PK/UP Spring Special ?
    stanyon
    stanyon
    Number of posts : 147
    65 PK/UP Spring Special ? Empty 65 PK/UP Spring Special ?
    Post by stanyon Tue Sep 24, 2013 1:37 pm
    As close as I can come with the VIN. E10TH697057 is that I own a 1965 truck with a 170 engine, built June of 65.
    I also have determined that I have a 9 inch rear end with 3.00 gearing and 2-1/2 brake shoes both front and rear. Truck came with the Spring Special exterior trim and chrome front and rear bumpers. Was there a cut off date for the Specials ?
    also my drums are garbage, is there a problem with using rear drums off a Ranger P/U ?
    The center hole is larger on the Ranger drums, so the drum would be floating on the front, is this a problem ? Thanks for the information.
    RichardP
    RichardP
    Number of posts : 77
    Registration date : 2013-08-10
    65 PK/UP Spring Special ? Empty Re: 65 PK/UP Spring Special ?
    Post by RichardP Tue Sep 24, 2013 3:10 pm
    Do you have a picture?
    Number of posts : 1747
    Post by econopoor Tue Sep 24, 2013 5:59 pm
    Can you post the other info from the data tag? There's a code on it that signifys a SS. Can't tell from just the VIN
    Number of posts : 2016
    Post by Barnabas Tue Sep 24, 2013 6:38 pm
    Your VIN falls in the middle of the Spring Specials, so it is possible.  It was rare for a Special to come with a 9" rear axle, but not impossible.
    I have one that I call a Spring Special, because it has a VIN like yours and has the side trim holes and the right paint color.  Unfortunately my doors were replaced and the door tag was lost.
    As was pointed out, the door tag has a special character for the Special.  Though Ford messed up a few door tags back in those days.
    Post by Barnabas Tue Sep 24, 2013 6:40 pm
    Is, or was yours painted Poppy Red?
    stanyon
    stanyon
    Post by stanyon Wed Sep 25, 2013 5:31 am
    The truck was originally Poppy Red, Vin tag on drivers door was removed by previous owner(s). I am trying to post pic's here but I am having a problem with my computer knowledge base. Thanks to all for the response.
    Post by econopoor Wed Sep 25, 2013 3:15 pm
    If it was Poppy red I'd bet it's a SS. Poppy was the default color on SS's. If no color was specified then it was Poppy red. Poppy wasn't offered in the option list. Only on SS's. Of course in the 60's you could get it painted any color you wanted if you were willing to pay for it but I've never seen any Econolines painted in Poppy red except the SS's. Your number is in SS production. The were built in May, June, and July. I'd be pretty sure it's a SS. You could get the 9" if you orderd a ratio that wasn't available in the 7.25 rear. Sometimes you can find a build tag under the wire cover on the passenger floor board. I've mainly seen those on 67's but it may have one under there.
    stanyon
    stanyon
    Post by stanyon Thu Sep 26, 2013 6:26 am
    Again thanks to everyone for there input. For now I will accept that the truck is a Spring Special.
    Has anyone made templates for the CardBoard interior piece's, or do you start cutting and fitting ?
    66ThunderVan
    66ThunderVan
    Number of posts : 384
    Post by 66ThunderVan Thu Sep 26, 2013 11:51 am
    Ranger brake drums won't fit properly. NAPA has new ones and they aren't that expensive.
    RichardP
    RichardP
    Post by RichardP Thu Sep 26, 2013 1:32 pm
    Speaking of card board inteiror pieces has anyone found these pre made. If not what sort of cardboard was used and how much of it is used.
    RE: Eco Pick Up
    Post by econopoor Thu Sep 26, 2013 7:11 pm
    If you need interior stuff talk to Fred Carello, He makes everything interior for Econolines. He goes by fmc56 on here. He has all the templates for all panels. Pretty reasonable as well.
      Current date/time is Sun Nov 17, 2024 10:53 am
