Hey guys,
I need some opinions on this one...
I've been working on keeping my van running cool for quite some time now and generally speaking, its been running great!
I currently have a new, larger core rad with a front pusher fan & back puller fan , i've got a belly pan with a modified wing to ensure air is getting up into the rad and the engine itself is pretty tuned as far as timing goes..
At low speeds, (under 50mph) the van runs cool.
As soon as I start getting upwards of +60mph or hitting longer hills on the highway that demand higher RPMS, the engine starts to really heat up..
My engine is a 170.
I'm somewhat stumped. In low air-flow situations, the van runs great. In high air-flow situations at speed (highway) the engine heat climbs.. You'd think it would be the opposite.
I was thinking about adding a heavier motor Oil (10w50) or adding an air damn at the top/front of the rad to ensure air is only passing thru the rad.. But I'm kinda grabbing at straws now.
I don't have the exact temps as my temp sending unit in my van is incorrect for the gauges. (I'm still trying to find the original size of the sending units for a '65 with a 170cc)
The gauges aren't accurate but they still respond to heat.. Ie: climbing & falling ..
I love any suggestions on this one..
Jes
My engine is a 170.
Jes
