Since I 've gotten my a100 . I looked at the location of the master cylinder (not any roon for a vacuum booster. But was thinking what would be the chances to install a GM HydroBoost from a chevy Astro van? just a thought . I have not yet looked into it. Just thinking it might work.
Hydro boost power brake system on a100 ?
The Early Chevy vans use a HydroVac system,,,,,,,it sits away from the stock master cylinder and the output line of the stock master cylinder runs into it then the brake line comes out of it to the wheel cylinders,,,,,but it is for a 1 line system not a dual line but thats probably what you still got,,,,,,now my 78 Chevy Van has the HydroBoost,,,,,,,a power steering pump and a big control valve that sits between the master cylinder and brake pedal,,,,,so that system takes up a lot of room and the pedal is behind the control valve and master cylinder where as our vans have the pedal in front of the master cylinder,,,,,,I don't know if that Astro is much different,,,,,,,,
