This setup uses hydraulic fluid pressure instead of vacuum.
I'm not sure if a power steering pump could be squeezed in to provide fluid, but you never know. The Slant 6 i bought to install came from a barracuda and included a PS pump (that i don't need). I had to remove the pump so the alternator could bolt in. However, if I could weld and had the $$, I think it would be neat to rig something up and put the alternator above the PS pump and use the brake system. V8 owners might have the room to add a pump? don't know. Like I said, a "wild" idea.
http://powerbrakeservice.net/new-1956-1966-dodge-truck-d100-w100-hydroboost-brake-booster.html
