Hi guys,
Thought I'd try upgrading to the weber 32/36 carb.All installed and fits beautifully, but can't for the life of me get the thing to idle. This is on my 250 which was running fine with the monojet on it before. Carb was purchased used on ebay, rebuilt it with all new gaskets etc. Linkage is working properly, all jets and passage ways have been cleaned and blown out with compressed air. Float has been checked for leaks and set at proper levels. Fuel is flowing and I am getting proper fuel pressure. Choke has been converted to manual. I have also checked for vacuum leaks with carb spray and did not find any.
Idle speed and mixture have been set to weber initial settings. The van fires up with the choke on and will idle with the fast idle engaged…which is basically the same as giving it more gas and taking it off the idle circuit, correct? The second I try to turn the choke off, it dies.
It came with a 45 idle jet installed, so I thought maybe by upping the idle jet it would solve my problem. I got a jet kit designed for 6 cylinders, so I've got a range of jets to choose from. I've tried everything from a 60 to 90 primary idle jet, and no change.
I feel like I have checked everything multiple times and have ruled out every problem I've read about.
Does anyone have any ideas what the problem could be?? Could my used carb just be defective??
