tommyfogarty
1965 VIN decode?
tommyfogarty- Number of posts : 126
Registration date : 2013-03-24
1965 VIN decode?
Hi all- I apologize in advance if there is a decoding section or protocol I should follow, but I am new here... I bought a 1965 A100 today. The VIN is 1962044213... Could someone decode? I tried to use an online decoder but it can't be right. Thanks!!!
Re: 1965 VIN decode?
Okay, I figured out the VIN decode, can anyone tell me where in the car I will find the paint code? Thanks!!!
I can't help you with your question but I am
Curious to know if you ever found your stolen 63 Econo?
No, unfortunately. It's a criminal matter at this point and the Sonoma County DA is pressing charges against the shop owner. When that is done there will be a civil suit. The whole thing is a drag. I really wish I still had that truck.
- Number of posts : 8731
if you go in to a100 links the paint colors should be there, as for a code i'm not sure what color is on the walls and in side the doors.??? ps. congrats on the van sounds like it needs a new name or smirf just might stick...
The whole van was repainted, for better or WORSE. I will scrape some paint in a door jamb or something but I was hoping the original color could be determined from a data plate somewhere.
look under the rubber weather strip either under the front/ side door weather strip or the windshild rubber.
JariV- Number of posts : 117
Registration date : 2013-04-25
Any old residues in the undercarriage anywhere?
I will give it a thorough look today after work. When I saw the van yesterday it was very obvious that I needed to buy it immediately, but I had no way to get it home without leaving my work truck, so I stashed it at a friend's house nearby. The paint job it just received was pretty excessive, so I have not found any original paint yet.
I will look under the headlight rings too, and behind the bulbs.
that will tell it all . I am only guessing but from your descripion of the paint work i dout they removed the door rubber,
Another sure place to look is around the heater, especially above it with a mirror.
Joe Van- Moderator 1st Class
- Number of posts : 4619
CONGRATS on your new VAN it looks GREAT Hopefully you will get to the bottom of the other issue and get some justice!!!! And money back also would be nice. ........JOE VAN...
congrats on the new van, first thing you need to buy is a manual off ebay just for your van, there you can find anything you need, if not just ask the guys on here, the manuals are great with paint codes wire diagrams, all kinds of specs,
Thank you- that's good stuff... A few more questions (knowing less, as I do, about the A series than I do about Econolines...): Are window rubbers available in case I decide to do a really proper re-paint? Are the headlight ring repros any good? What is the standard offset and backspace for the wheels??
I will post pics- you will like this van!
Thanks all!!!
Thanks all!!!
All weatherstrip is available as new. I'd say stay away from repro headlight rings. Can't help you with the original wheel size as I don't even know if the set on mine before I made the rears wider was original or not.
I've heard the repop rings are nice????
- Post n°19
the ones on ebay for 80.00 i guess are nice, from what i hear
- Post n°20
The repop head light rings selling for $80.00 on e-bay are top of the line work (very nice) what window are we talking about, front doors or the barn doors ?? are they the stationary of pop outs?? the stationary barn door windows is what i'm not sure of.
- Post n°21
Front windows and non-pop rears. Oddly, the front window rubber looks and feels brand new. I think they put new glass and seals in the front and then painted right over it!!!
