+6
SteelyVan
ndjarrett
10 posters
    So much for the "rebuilt" engine
    ndjarrett
    ndjarrett
    Number of posts : 357
    So much for the "rebuilt" engine Empty So much for the "rebuilt" engine
    Post by ndjarrett Sat Apr 06, 2013 1:54 pm
    As hell. Cyls 1,3,4 all have 150 compression. Cyl 6 only gets 100. Cyl 5 keeps pulling the damned rocker loose so who knows. And the best of all...cyl 2 with a total of zero. So much for the engine supposedly being rebuilt!
    Anybody close to Memphis got a decent 250? LMFAO
    Number of posts : 12188
    So much for the "rebuilt" engine Empty Re: So much for the "rebuilt" engine
    Post by donivan65 Sat Apr 06, 2013 4:38 pm
    You might just need to get that head rebuilt or another one,,,,,
    So much for the "rebuilt" engine Empty So much for the rebuilt engine
    Post by Joe Van Sun Apr 07, 2013 1:16 pm
    I agree with donivan pull the head off have a valve job done resurface it and tell them to install screw in rocker studs and you will never pull a stud out again.and make sure you are not setting the valves too tight also..................................................................................... A Rebuilt engine with 10k and 5 hours away sound's great I would look into that for sure if the price is right. I had a 454 Chevy engine shipped from summit racing in Georgia to Florida about 5-6 hours( if I drove) for $ 165.00 Shipping may be cheaper than driving just in gas alone.
    Number of posts : 890
    Post by jrinaman Sun Apr 07, 2013 7:58 pm
    take .060" off the head and you can gain a full point in compression, still cheaper than a new motor. i do have a rebuilt 6 with less than 10k on it but shipping would probably be a deal breaker.
    Number of posts : 8685
    Post by dix Mon Apr 08, 2013 2:55 am
    it's about a 5 hr drive
    SteelyVan
    SteelyVan
    Number of posts : 112
    Post by SteelyVan Mon Apr 08, 2013 6:59 am
    Hello jrinaman,
    Sending you a PM.
    SV
    Brian in Michigan
    Brian in Michigan
    Number of posts : 10
    Registration date : 2013-03-19
    Post by Brian in Michigan Tue Apr 09, 2013 5:12 pm
    Shoot some oil in Cly 2 see if the compression rises at all. If not you may have a valve that is stuck open.
    Post by donivan65 Tue Apr 09, 2013 6:11 pm
    Why do you think this is a rebuilt engine? are the valves adjusted correctly? if you wanted to analyze the engine you should get a Cylinder leakdown tester that puts air into each cylinder and tells you how much leaks out,,,,and if it is excessive, you listen at the tailpipe, and carburetor to determine if the valves are leaking,,,,,,watch the coolant level to see if the head gasket is leaking and listen in the oil filler hole to hear if the rings are leaking,,,,,I have pounded those studs down and drilled and put a roll pin in it to keep it from pulling out,,,,,,,but you got a lot of options of repairs depending on what you have more of,,,, money, time, or brains.......
    Number of posts : 655
    Post by vanner68 Sat Apr 13, 2013 4:15 pm
    Did a leakdown test of a friend's 200,000 mile Ford Fairmont, got to #3 cyl and the dipstick popped out of the tube! All I could say is 'Guess we found the source of the miss!'
    ndjarrett
    ndjarrett
    Post by ndjarrett Tue Apr 16, 2013 6:55 pm
    Ya...i hooked an air hose up to #2 and heard it hissing thru the intake and Carb. So, I've pulled the head and took it to the speed shop to get reworked. I hope it don't take too long to git-r-done. They needta pull all the rocker studs and put new ones in too cause at east one...probly two...were pullin out on their own.
    ndjarrett
    ndjarrett
    Post by ndjarrett Tue Apr 16, 2013 6:58 pm
    The dude I bought it from said it was rebuilt a coupla years ago by Jasper engines and so I took him at his word.
    So much for the "rebuilt" engine Empty Jasper
    Post by millwright71 Wed Apr 17, 2013 8:57 am
    There is your answer! I have not had any luck at all with Jasper engines.
    Post by Twinpilot001 Wed Apr 17, 2013 10:28 am
    I think we all =at one time or another =have been trusting in what someone said -bites us hard when isnt too! Sadly - just costs us money. Sad affraid
    Post by donivan65 Wed Apr 17, 2013 10:52 am
    Maybe loose rocker studs were the only thing Jasper forgot to check and fix,,,,,,,however,,,,,,the head needs to be flat,,,,with no cracks,,,,,hardened valve seats installed,,,,valve guides not worn,,,,valve springs still good,,,valves have to seat tight and new seals installed,,,,,,and rocker arms not worn,,,,,,,,so lets see what they find,,,,,,,,and check.......
    ndjarrett
    ndjarrett
    Post by ndjarrett Thu Apr 18, 2013 3:31 pm
    I am no expert...but it looked like all that was done, if anything, was a quick and dirty valve job. Don't think it had hardened seats put in...but maybe they are there under the gunk...lol...but doubt it. The rockers all had decent wear marks/grooves where they sit on the valves. Probly needs everything new. Valve seals were definitely leakin on two cyls.
      Current date/time is Fri Sep 29, 2023 10:50 am
