by SDEconoTruck Mon Mar 18, 2013 9:06 pm
Sid dropped my axle, excellent work. In fact if you scroll to the bottom of the page, that is my axle. Highly recommended as he even massaged the kinks out. (That's how they did front end alignments on Econos by bending the axles with a special factory tool, mine was "adjusted" several times, ha ha.)
George
Also went with dropped tie rod ends from Speedway rather than adapters, much cleaner
Bought a ream tool from Edco and did my own kingpins
Of course, I ended up re-doing the springs and bushings as well, I posted a thread on here someplace as a "How-To"
So, if you are getting a dropped axle, there are other things you can do at
the same time, knock it all out and it will be great.
You might get a little clearance issue on the DS bump stop as the axle will be 3/4" narrower, (I had to narrow the Tie Rod a bit) but overall it was pretty straightforward and kinda fun!
