who is the best place to buy rear axle disc bk kit ? my 66 got a 12 bolt in it do i want for a truck axle or were there cars that crossed over ??
rear disc brakes
Bear- Number of posts : 849
rear disc brakes
Re: rear disc brakes
Pretty sure this is what I got when I did mine, I didnt get the backer plates tho.
http://www.summitracing.com/parts/rsd-afxrd01/media/images
The brackets are installed as flat with the right shims(included). The rotors are 79 Firebird rears, the calipers are 85 eldorado types. Hoses I think are even 79 firebird. pretty easy install, just a couple things you have to keep in mind for being able to service them. Keep enough slack in the E brake cables to pull the calipers back to remove them and have the hoses mounted to be able to do the same. And like on the front conversion , you have to make sure the axle flange is filed or ground back to get the rotors to lay flat.
