by m1dadio Wed Feb 27, 2013 5:07 pm
I mailed one through the post office into the US.
You must clean it out very well with hot water and detergent. and then wrap it up in garbage bags two or three times so it is air tight then wrap it in cardboard.
When you sign the slip for postage or with a courier the fine print says you are aware you are not sending unmarked "Dangerous Goods" it is a federal offence in Canada and is a $800,000.00 fine.
M1D
