i got a 64 chevy van and went to replace the kingpins. i took them apart real fast and did not see where the rubber o-rings came out of. i'm thinking their from the bottom of the bearing or the top of the washers. anyone help me out. john
KINGPIN O RING
JOHNFIELY- Number of posts : 124
Registration date : 2012-08-30
KINGPIN O RING
Re: KINGPIN O RING
They would go like if right before you pushed the upper bushing into the steering knuckle, you put the o ring in the hole and the bushing pushed it down to where it belongs,,,,however,,,,I wouldn't worry about it if the o ring did not like staying in there while you try and put it all together,,,,,,,,,
