+49
66mnecotruck
back2thewoods
jfox
Dawgboy
NipRing
SteelyVan
SDEconoTruck
rustybug13
Vantastic
kaz
Leftcoast65
kookykrispy
sandyvan
64chevy
53 posters
The Surfing Guy's 65
- Post n°651
Re: The Surfing Guy's 65
looks great, its nice fealing when you get one back together and get out on the road,,
the_surfing_guy- Number of posts : 409
Registration date : 2012-08-15
- Post n°652
Yes it is dodge man! Thanks for the compliment.
- Post n°653
I really enjoy just the everyday run around things that get done with the van. All the thumbs up, and smiles make it fun for sure.
- Post n°654
Just look out for the loose shopping carts. Nasty little dents from those suckers! Glad to hear your On the Road Again!
- Post n°655
vanny wrote:Just look out for the loose shopping carts. Nasty little dents from those suckers! Glad to hear your On the Road Again!
Thanks Vanny! Its good to be...
- Post n°656
Well, today was the maiden voyage down to the beach with the van for a surf and cruise...
Later Don met me down there
and as luck has it, it was a good thing too. Seems my alternator took a crap on me and would no longer charge. The van would run once it started, but pretty much every time I would kill the engine, I needed his battery charger(s) to help me get started. That's right, chargers...one wasn't enough.
We cruised some more, got some food and headed back to my house. Once there we did some diagnostics and Don will tell the rest of the story...
- Post n°657
- Post n°658
Like a guardian angel! Glad it all worked out and you made it home without a tow! New alternator in the shopping cart?
- Post n°659
Yeah Vanny. I bought a new alternator and a new battery (mine was the original one from when I bought it and it was tired). Then Don came by and re-clocked it. We installed it and everything is running like a top. In fact, now that I have a new battery I was able to hook my stereo up to a terminal on the fuse box with constant power and keep stored memory on the stereo. In other words, I can program radio stations, but more importantly when I turn it off and then back on, I don't lose my spot on the Mp3 order! Ready to cruise again...
- Post n°660
- Post n°661
Nice that it's down to minor things now. Glad to hear you can cruise with tunes and not lose your place! Surf's up ! Cowabunga!!
- Post n°662
Rayallen- Number of posts : 648
- Post n°663
Are those pics of the Ocean Beach area? Loved that place when my wife and I visited last year.
Killer van dude, Dig it!
- Post n°664
- Post n°665
Very nice scenery! Vans look good too!
- Post n°666
MAN I WISH I COULD JOIN YOU GUYS, THE LAST TIME I DROVE OUT THERE WE WENT THROUGH SAN FRAN, AND HEADED NORTH THROUGH THE GIANT RED WOODS, MADE A BIG CIRCLE AROUND THE US, THAT WAS 8 YEARS AGO NOW, I MISS THAT WEATHER IN THE SOUTHERN STATES,
- Post n°667
- Post n°668
I'm hoping you were just taking in the scenery and not broke down! Did Scottie take that pic?
- Post n°669
- Post n°670
Sure beats shoveling snow! Nice pics Don!
- Post n°671
you had the only red vehicle there, you can spot your van real easy, lol great pictures,,
- Post n°672
speedometer / odometer cable diagnosis
This weekend I tightened up a few loose ends, so to speak. I found that my lower radiator hose had a few drips of coolant on the end, so I tightened up the clamp, I zip-tied up all of the wiring under the dash (voltage/water temp gauge, stereo/speaker wires, fan switch, etc.), and re-sealed the doghouse gasket/insulation that was coming off.
Other than those minor things, I tried to diagnose my speedo/odometer issue (they do not work). First, I unscrewed the cable and re-seated it to the back of the dash. That did not work. Then, per Don's recommendation, I unscrewed the cable at the transmission and hooked up the drill to the steel cable that is inside. I then had my wife/soulmate check the speedometer and we confirmed that the arm on the speedometer tilted to 50 mph. This tells me that the cable is hooked up ok at the dash and that the cable is not broken. So, I detached the whole cable/adapter at the transmission and checked the plastic gear and it seemed fine. Then I spun the steel cable with my fingers and the plastic gear turned, so I am assuming that the plastic gear is not meshing with the teeth inside the transmission??? Don?
- Post n°673
- Post n°674
RipVanArkie- Moderator
- Number of posts : 987
- Post n°675
Gear reduction box...
Later,
Rip
2013 MidSouth Econoline Meet
1967 Econoline Pickup
1966 Econoline Supervan
