You'll like that HEI for sure, makes it nice to hook a tach up also. I never did understand why they routed the wiring harness on the left side of the DHs when all the stuff they have to hook to is on the right.
+7
wacko
11 posters
Laundry Basket(case)
- Post n°26
Re: Laundry Basket(case)
- Post n°27
wideload- Moderator 1st Class
- Number of posts : 1388
- Post n°28
WOW !!!!!!!!!! I see Fiero seats too!!!!!!!!! You'd think you were getting ready for the nat's or something
Mike
WIDELOAD
- Post n°29
OOOOH!! Baby moons. I like that!
- Post n°30
Looks good Moe!!!!
- Post n°31
Thanks y'all ! My mind set/philosophy is : Anytime I turn a ratchet or wrench to the right,no matter what it is,I'm makin an improvement. Or thats what I am trying to convince myself,heh
- Post n°32
Finally cooled off enough and had the chance today to remove the tank.What mess inside.It had 3 lbs. of the funk of 41 years built up in it,but had to be done.Whole lot of washin,handfull of rocks and rinsing,it's comin pretty clean.Gonna try the anti-freeze trick as well.Repeat and rinse.Gotta get a tank seal & new float & sock.Fuel s/u works though.Thats a good thing.These are the before pics.
- Post n°33
Nightmoves working on one more thing to take off your list. Keep those pic's coming
- Post n°34
Another step towards the Nat's !!!!!!
Mike
WIDELOAD
- Post n°35
Man thats really yucky lookin in there!Whats the antifreeze trick? I usually just use a 3' heavy chain and a gallon of kerosine repeat as needed
DanTheVanMan- Commissioner
- Number of posts : 7900
- Post n°36
Moe, I have spare sending unit parts if you need them...
Dan
Dan
- Post n°37
- Post n°38
What you got on your mind for trying to fix it ?????????
Mike
WIDELOAD
- Post n°39
Duct tape.Haaaaaaaa (inside joke)
Kinda up in the air.I've heard solder,J-B weld,even thought about spot wire weld.Afraid it might make bigger that started out with.Other than the obvious 3 1/8 " holes,found several lil pin holes away from the edge.I'll come up with something.
- Post n°40
I brazed a tank years ago, we ran exhaust from another car into the tank till we could see it coming out the holes for quite a while before we started brazing.
econopoor- Econoline Guru
- Number of posts : 1747
- Post n°41
Man. That looks like a ruff job saving that one. I should have saved the tank from the GMC. It wasn't that bad.
Duane.
Duane.
- Post n°42
I know some will roll thier eyes at the idea, but I have used that stick type of epoxy ( it works up kind of like silly putty) on some truck tanks and even put some on my van in some places that "looked" in need of some extra thickness. It may not last forever but it held up for better than 5 years on the bottom of a diesel tank, Should buy some time if you want to find a better one anyway. just get it as clean as you can first then seal it up with paint.
