    Time to build the engine
    gkpost
    gkpost
    Number of posts : 224
    Time to build the engine Empty Time to build the engine
    Post by gkpost Tue May 08, 2012 9:26 am
    So after the engine in the van was taken out and found to be junk, I got a second engine from a friend ( who I'm sure had all good intentions ) and it's also junk. I found one in a bone yard for $100 and it's good, and I'm happy. So now it's time to rebuild and up grade. I had thoughts about bigger motors but have come to the conclusion that keeping it simple is the way to get it finished.
    My plan is to use a tripple carb manifold w/single barrel rochesters, cast headers, and a mild cam. Also I was thinking about having the head shaved.
    So, while it's apart and I still have not ordered the parts,any suggestions ???
    Number of posts : 512
    Time to build the engine Empty Re: Time to build the engine
    Post by pan58head Tue May 08, 2012 11:44 am
    GK I think in the long run you will be happier with a v8, I know its a bit of a swap , but it not that bad . I also sent you a pm Bob
    Number of posts : 1651
    Post by Scott Tue May 08, 2012 12:26 pm
    The more aftermarket stuff I added to my L6, the more I had to buy to make it work. If I had a do-over I would probably make the jump to a v8, or keep the L6 stock. My Offy intake pushed the carb to the wall. If I hadn't dropped the engine to accommodate the 200-4r transmission the Holley linkage wouldn't have fit. And when I had the Edelbrock, it was rubbing the paint off the doghouse lid.
    And with a v8 you will have way more parts to choose from..
    And once you hop-up your L6, it's just as thirsty as a small V8.
    I originally kept my L6 because everyone always jumps to a V8. Kind of a coolness factor. Well, I should have kept it stock, it cost way to much to make the aftermarket stuff work / fit right.
    Now that it's running I'm happy with it, but the V8 would have been much more simple, and less money.
    Either way you go, I'm looking forward to pictures of your build.
    Here's a couple of pictures of the two carbs I was working with.. The Edelbrock 600cfm was to much for the 250 L6. So I switched to the Holley 390cfm.
    This one is the Edelbrock,
    Time to build the engine Screen76
    Here's the Holley,
    Time to build the engine Screen77
    As you can see, the Holley linkage is just under where the doghouse gets a little wider.
    Post by Guest Tue May 08, 2012 7:24 pm
    here in the states almost nobody knows how to tune l6 engines the right way, but is possible to get 50 more horses and 24 mpg with a stock engine plus intake manifold, headers and 2bbl carb...people I know are getting 120 horses per liter, you have 4.1 liters in a 250....go figure....v8??...no, thanks..
    Number of posts : 890
    Post by jrinaman Tue May 08, 2012 9:08 pm
    307 flat top pistons fit, will raise compression. you can mill up to .100 of head without clearance problems but .060 is recomended for longevity. shaving head alone will raise 1.1 on compression. 1.94 intake valves will fit. when selecting cam, your duration will determine powerband. pick duration you want and search for highest lift you can get.triple intake is same as stock. Time to build the engine Intake20
    Leftcoast65
    Leftcoast65
    Number of posts : 77
    Registration date : 2011-08-27
    Post by Leftcoast65 Tue May 08, 2012 11:01 pm
    devimau wrote:here in the states almost nobody knows how to tune l6 engines the right way, but is possible to get 50 more horses and 24 mpg with a stock engine plus intake manifold, headers and 2bbl carb...people I know are getting 120 horses per liter, you have 4.1 liters in a 250....go figure....v8??...no, thanks..
    I'm here in San Diego and I'm VERY INTERESTED in learning how to tune my stock L6 to get 24 miles a gallon!!!! Please contact me.
      Current date/time is Fri Nov 22, 2024 5:34 pm
