bought a nos carter 1 barrel for the slant - cleaned it up, threw it on, need to get a new carb to manifold gasket but fired it up anyways - already a big improvement, even though i need to do adjustments and i find the throttle cable is binding up sometimes- i can see its around the cable right as it comes off the pedal below the floor board - it may be a non stock cable from a previous owner - i no longer have to let it warm up for at least 5 minutes just to have it stumble down the road still - yes i could have bought a kit and have had at rebuild - but probably still could have used a throttle shaft rebush and ? - now after a quick ride around the block i notice a couple of small oil puddles in the driveway - it does not drip when off, but while running i have a drip drip drip coming from between the engine and trans ( manual ) area - sob !! - something else to deal with - oo3
