    Blown head gasket on 230 ?
    sparky
    Number of posts : 195
    Blown head gasket on 230  ? Empty Blown head gasket on 230 ?
    Post by sparky Fri Feb 24, 2012 6:48 pm
    I think I have a Blown or leaking head gasket, I noticed some water under the van and layed down under to check it out and saw some drips and steam coming outta the overflow hose, I also noticed up at the head where it meets the block I saw something that looked like a water bubble and pop, like maybe steam bubble ing out there? I have never really seen to many blown head gasket indications before on anything so not sure what to look for, has no excessive smoke, I havnt looked at the dipstick yet but will in a few moments, (for water and oil mix) kinda bummed, hoping engine is not ruined, its not running terribly bad but not perfect either, I have never pulled the head off of one of these and not even sure where to begin....I guess pull carb/ intake/manifold off, pull valve cover..then ? maybe this is all mentioned here somewhere else ?
    Number of posts : 12248
    Blown head gasket on 230  ? Empty Re: Blown head gasket on 230 ?
    Post by donivan65 Fri Feb 24, 2012 8:09 pm
    If you have a pressure tester, you could pump up the radiator and see if it holds pressure and if there are leaks anywhere,,,,,If you want to pull the head, the basic way is undo the fuel line, temp sender, plug wires, upper hose, choke cable, carb linkage, and exhaust pipe,,,,,pull the valve cover and undo the head bolts,,,,,,then the whole thing coves off,,,,,or take it off piece by piece,,,,,,
    sparky
    Post by sparky Sat Feb 25, 2012 2:24 pm
    Sounds easy enough, I need to get on it asap , Thanx!! it just lifts right out?
    Post by Digz Sat Feb 25, 2012 2:32 pm
    If you leave it all in one piece ,you might want a buddy handy to give ya a hand lifting it or use a shop crane.
    Post by donivan65 Sat Feb 25, 2012 8:45 pm
    It sure is easier to lift off the more pieces you take off,,,,,the pushrods will be still sticking in the block if you don't 1st loosen each rocker arm and pull out each of them before you pull the head,,,,,,,,otherwise you will need to loosen the rocker arms and turn them a little to slip the pushrods back down through the head and adjust them after the head is back on,,,,,,
    sparky
    Post by sparky Sun Feb 26, 2012 8:42 am
    someone was tellin me that if the oil and water have mixed and ran thru the bearings... then engine has to be rebuilt ?
    sparky
    Post by sparky Sun Feb 26, 2012 1:32 pm
    The oil just looks burnt black oil, took off the valve cover...found what looks like the tip of a pushrod tube in a headbolt recess in the head next to the bolt.
    Post by donivan65 Sun Feb 26, 2012 7:24 pm
    Water or coolant turns the engine oil into kinda like a chocolate milk shake,,,,,it's not deadly unless you ran that engine a long time,,,,,it would probably clean out if you drained it out and did a couple of oil changes with some cheap oil. Loosen the rocker arms and pull up each pushrod and check them for damage,,,you really need to take all the rockers off and inspect them and the valve stem tips to see if they are all chewed up,,,,,,
      Current date/time is Tue Nov 26, 2024 4:40 pm
