did you come up with a parts list as you are doing what i want to do. using all dodge stuff.
+9
Mr. John
13 posters
Disc Brake conversion
jkr- Number of posts : 1148
- Post n°26
Re: Disc Brake conversion
Mr. John- Number of posts : 42
Registration date : 2008-12-13
- Post n°27
Yes I'll be posting a list the only non Mopar piece are the rotors.jkr wrote:did you come up with a parts list as you are doing what i want to do. using all dodge stuff.
kiwimopar- Number of posts : 740
- Post n°28
so I'm guessing the rotors are of Ford origin?
- Post n°29
kiwimopar wrote:so I'm guessing the rotors are of Ford origin?
heaven forbid ford parts on a mopar.
actually had my hands on 2 sets of spindles and caliper mounts today off an older a-body dodge. that is what you look to be using in your pics so far and i was planning on using diplomat/5th avenue rotors. need to make a sleeve for the seal but otherwise very close to a bolt on.
- Post n°30
jkr wrote:kiwimopar wrote:so I'm guessing the rotors are of Ford origin?
I hear ya on that one, but since the stud pattern is the same....
- Post n°31
Yes the rotors are FORD but we stole the idea for our little A1's so technically it's all ford!!!!
95-97 Crown Vic just use your existing hubs I used JEGS long studs for my Cragar rims. Still working on the list with part #s and prices.
- Post n°32
Plates are done the water jet is amazing!!!!!
She's almost done.
She's almost done.
- Post n°33
Looking gooooood
kcmojayb- Number of posts : 4
Registration date : 2011-08-31
- Post n°34
OK guys, I've got a 64 A100 window van with manual brakes and steering. I'm dying to drive this thing on a regular basis but..stopping is an adventure. I was getting ready to dive into a stock once over on the brakes and found this thread. Is a disc conversion even a possibility with M/brakes? Do I need to look into an electric hydra-boost setup? or?.. Mr. John, how did your self kit work out? Any advice would be great.
Thanks
Jason
Thanks
Jason
- Post n°35
kcmojayb wrote:OK guys, I've got a 64 A100 window van with manual brakes and steering. I'm dying to drive this thing on a regular basis but..stopping is an adventure. I was getting ready to dive into a stock once over on the brakes and found this thread. Is a disc conversion even a possibility with M/brakes? Do I need to look into an electric hydra-boost setup? or?.. Mr. John, how did your self kit work out? Any advice would be great.
Thanks
Jason
Jason, She stops! She finally stops! I love driving this thing now! No pulling no chatter, no fading! I love it!!!!!
Here's the link to my Photobucket conversion pics.
I can get the plates made I think E-mail me if interested.
https://s838.photobucket.com/albums/zz306/mrjjohn/A100%20brake%20conversion/?start=all
- Post n°36
Awesome picture tutorial Mr John
- Post n°37
What application is the master cylinder for? I assume a front disc car seeing the reservoirs are different sizes. Could you have keep the stock dual outlet master and added an adjustable proportioning valve? Speaking of which I did not see any pictures of a proportioning valve, what are you running?
- Post n°38
white-lightning wrote:What application is the master cylinder for? I assume a front disc car seeing the reservoirs are different sizes. Could you have keep the stock dual outlet master and added an adjustable proportioning valve? Speaking of which I did not see any pictures of a proportioning valve, what are you running?
The master I used is for the 73-75 Dart.
The master was changed to utilize the larger fluid reservoir fear of running out of brake fluid would occur using stock drum master.
No proportioning valve needed which is just a shuttle valve for the brake lamp in the event of fluid loss in either reservoir.
- Number of posts : 8729
- Post n°39
what caliper mount is used?? and did it need to be machined???
- Post n°40
dix wrote:what caliper mount is used?? and did it need to be machined???
See the pictures in the Photobucket link a few posts above, i explain what parts I used the plates were cut out on a water jet!
- Post n°41
i am havind a problem with the photobucket it's locked...
- Post n°42
dix wrote:i am havind a problem with the photobucket it's locked...
don't know it's tagged public just checked again!
I used the mount that came from the doner car 73-75 Dart Valiant
Old Skool- Econoline Guru
- Number of posts : 1306
- Post n°43
Just picked up a 67 A-100 pickup and looking to see if anyone had disc brakes myself!! I make them for the Fords and have all the different rotor spec books. If no one is making a set then I was thinking of making some myself. I wont drive any of my Fords without disc brakes and feel the same about my Dodge. Always wanted one, and no I have one. Also looking for short donout mount tail stock for a built 727 I have had laying around forever. It is hooked up to a married 205 right now, if anyone is interested in the 205 and the adapter housing..
vic
vic
