We have an '87 Mercedes 560sl with 110,000 miles. It had sat a year or more undriven after the previous owner had issues with it not wanting to get up to speed. It was very lightly driven before being parked with only a few thousand miles put on it in several years.
Before parking, previous owner replaced the fuel pump (Chinese, not Bosch) and lots of other stuff and nothing fixed it. We purchased it, towed it to Mercedes mechanic of over 20 years and he had it a long time before finally re-lining the tank. In the process, the fuel pressure regulator and fuel distributor? were also replaced. It was assumed that crap from the tank was getting into the fuel system and re-lining the tank fixed the two previous failed attempts at making it home with replacement fuel system parts.
The car ran well for a bit, but then started running poorly/sputtering a bit at idle. My wife described it as the car not going forward at times from a stop with your foot off the gas. Cars normally continue forward with no gas, but it was "heavy" and was taking more effort to go from a stop. The problem is/was sporadic. It was running fine at speed.
She took it in, two weeks later, they say nothing to worry about and that it's one of the best running 560's in town. Perhaps a vac leak which is hard to track down.
She drives it home and a day or two later it starts having problems at 65 going up a bridge. Won't go past 65. Below that, fine. Back at 65, hits the wall like a gust of wind. Shortly thereafter, the car won't go and she loses power where it's even hard to make the car steer (something we understand.) Towed to mechanic, can't find anything wrong other than the idle sputtering a bit. He's driven the car all over and I've run into him, so I know he isn't B.S.ing me.
They've had the car more time than we have. Great V-8, just can't get the kinks out.
Any wild guesses?
