    a727 transmission
    andrew carter
    andrew carter
    Number of posts : 465
    Registration date : 2011-09-04
    a727 transmission Empty a727 transmission
    Post by andrew carter Sun Jan 22, 2012 7:09 pm
    changing over to automatic found a 69 a100 with a 225 with a727 trans will this trans bolt up to a 318 any help greatly apprciated
    white-lightning
    white-lightning
    Number of posts : 237
    a727 transmission Empty Re: a727 transmission
    Post by white-lightning Sun Jan 22, 2012 8:19 pm
    Does it have an adapter plate? Some /6 had v8 trans and used an adapter plate, so if it has one take the plate off and it will bolt up. Don't toss the plate someone will probably want it.
    Number of posts : 957
    Post by slowflapper Mon Jan 23, 2012 10:20 am
    This might help as well:
    reference
    Number of posts : 3046
    Post by RodStRace Mon Jan 23, 2012 12:14 pm
    Short answer, no. I understand that only early /6s had the adapter. Later ones have the /6 bolt pattern and will not interchange with a cmall block pattern.
    If you can find a small block 727, the internal parts and rear shaft/tailhousing can be swapped to make a V8 shorty trans.
    Talk to your local transmission shop about this before buying stuff. They may have the correct core or a core they can mix/match to build what you need.
    Number of posts : 1148
    Post by jkr Mon Jan 23, 2012 2:23 pm
    look at the case. if the starter mount is high no it won't work with a v-8. simple as that.
      Current date/time is Tue Nov 26, 2024 2:57 pm
