    Help Me ID This Trans Please
    Number of posts : 957
    Help Me ID This Trans Please Empty Help Me ID This Trans Please
    Post by slowflapper Wed Jan 18, 2012 7:34 am
    Morning all,
    I found a guy not too far from me that has a 1970 Sweptline Pickup with a LA 318 and a 3-speed manual trans (column shift). I just happen to be looking for both of these parts and he's going to make a fair deal on them.
    What I haven't been able to find out is what kind of transmission it actually is. My /65 A has an A-745 manual in it, I think that's the same trans that's in this '70 Sweptline but I haven't been able to find any details at Allpar etc.
    Anyone know off hand if they used the 745 in ' 70 Sweptline pickups?
    Help Me ID This Trans Please Empty Re: Help Me ID This Trans Please
    Post by Guest Wed Jan 18, 2012 8:35 am
    They used the A-745 in '68.
    Number of posts : 1868
    Post by HandiVanMan Wed Jan 18, 2012 8:40 am
    Maybe you can find some info at this site.....
    http://www.sweptlinetruck.com/engines.php#1970
    Post by slowflapper Wed Jan 18, 2012 9:35 am
    HandiVanMan wrote:Maybe you can find some info at this site.....
    I checked it before but its not very conclusive:
    1970 Model Year:
    Transmissions for 1970 for (both standard and automatic model types) saw significant upgrades. A new 3-speed, fully synchronized manual transmission was made standard on all half and 3/4 ton pick-ups with the 383 V8. This transmission was also made standard on the D200 and W200 crew-cabs with the six-cyl. engines. The new transmissions provided more versatility for rugged terrain or heavy loads. In the engine line-up Dodge intoduced a new 198 ci six-cly. motor. This engine became standard offering and the 225 six & 318 V8 became optional.
    Post by Guest Wed Jan 18, 2012 10:04 am
    I've been looking through my books a parts manuals but the newest I found was '69 for 745 in the sweptlines. That is only because I don't have a manual that covers a '70 truck. Good luck though... Smile
    Number of posts : 3046
    Post by RodStRace Wed Jan 18, 2012 12:02 pm
    So long as it's not a big heavy duty trans with the PTO plate on the side, it should swap out.
    Keep in mind that the driveshaft end may be different.
    Post by slowflapper Fri Jan 20, 2012 7:39 am
    Thanks for the input everyone, I just found a couple of pretty good sites that have trans/engine related data. Take a look here and here.
    Post by RodStRace Fri Jan 20, 2012 7:42 am
    Good to see a bit of research!
    Nice links, that should be enough for you to get the info you need!
    Post by slowflapper Fri Jan 20, 2012 7:53 am
    Yep, and it answers a few other questions I've been pondering in regards to my engine swap as well. The first site lists clutch sizes for engine/trans combo's which comes in handy.
    It looks like the 9.5" clutch was used with the A745/273+318cid combos which is good to know, that means my existing trans/bell housing/clutch will bolt right up to a 60's/70's LA 318.
    One less thing I have to worry about Smile
    Post by Guest Fri Jan 20, 2012 10:17 am
    slowflapper wrote:Thanks for the input everyone, I just found a couple of pretty good sites that have trans/engine related data. Take a look here and here.
    Thanks for the links!! JP
    Post by HandiVanMan Fri Jan 20, 2012 10:21 am
    slowflapper,
    What part of Ga are you in?
    Post by slowflapper Fri Jan 20, 2012 10:52 am
    I'm in Forsyth County (Cumming/Dawsonville area)about 60 miles E/SE from Calhoun. Is you van running? I do a lot of car shows in the spring and summer around here if you want to try and meet up at one.
    Post by HandiVanMan Fri Jan 20, 2012 1:13 pm
    I am working on trying to get it road worthy it has been sitting since 2004. I have got it running but still have to do some work on the carburetor, brakes & ??? once I get it on the road. I would love to take it to the car shows but it might be a while before I am through with it. I am just getting to work on it as I get time to which is few and far between...I know where dawsonville is... The home of awesome BILL
    Post by slowflapper Mon Jan 23, 2012 10:24 am
    Well, if you get it road worthy thats all it takes, Im far from being finished with mine but when you have the only van there you dont have much competition Smile
      Current date/time is Mon Nov 25, 2024 5:34 pm
