The car now has 500 miles on it and hasn't shown any real defects, such as bad handling or brakes. In fact the brakes are brilliant.
I've got a couple of niggling problems but nothing that will stop the car being driven.
I still have the coolant leak which I first thought was from the Corvette radiator header tank so I ordered a new one from the States and fitted it. No joy. Oh well keep looking.
The other problem has been a small leak from the tail-housing of the transmission. I suspected a shot oil seal as the spud shaft that couples the two trans together has pins inserted in (one part is forged the other cast so they couldn't be welded together) it that could be damaging the seal. I took the transfer out a couple of weeks ago and put a speedi-sleeve on the shaft, a new seal and reassembled it.
Here's a photo of the shaft and the pins. You can see where the seal has wiped over the pins.
Unfortunately it still leaked.
I took the transfer off again on Friday (it takes around 10 hours to remove and replace it) and found a pin hole in some welding I had done on the housing. I had this re-welded today and now have it back together.
You can see the area with weld on the right had side of the tail housing. The steel plate is what joins the two transmission together. You may also notice I didn't remove the end of the sleeve as it wasn't in the way and had less chance of getting distortion by leaving it on.
Hopefully I now have the problem fully sorted.
Whilst under the car I found a loose hose clamp so I've gone over all the clamps in the system (there are about 20 of them!) and checked they were tight. Hopefully it will be another problem sorted.
Some good news is the car has been accepted for Motorex (
http://www.motorex.com.au/ ) which is Australia's premier custom car show so now I'm in full swing to finish off the paint work as it has a few scratches from when it was assembled that I need to get rid of.
I'm looking for new front wheels for it as I'm not happy with the ones on it. They don't fit the 70's image of the car so tomorrow I'm off to a wheels re-seller to browse his stock and see what I can use.
I'm really happy with the way the car drives. It handles and stops well and while it's still a forward control commercial vehicle it has much better road manners than most of these little trucks over here. Somewhat faster as well.
One thing I haven't done with it yet is try any drag starts. I know the front suspension unloads a lot when you first move off from a standing start but not sure if I was really aggressive if I could get it to lift one or both front wheels. Maybe I'll find out after Motorex, just in case I break something.
I'll try and get some more photos of the car and some video of it on the road and post them up.
