    ever bend a tierod?
    Number of posts : 890
    ever bend a tierod? Empty ever bend a tierod?
    Post by jrinaman Fri Dec 02, 2011 4:32 am
    trying to get a few more trips in the van before xmas. hooked up the heater yestarday and went for a drive. other than needing a hotter thermostat, all was good so i went to gas station before returning home. traffic backed up at light so i jumped the curb to get in gas station. felt funny turning it around and while filling, i noticed front tire looked low and was leaning a little. i proceeded to squeeze in every drop of gas i could so i could use it today. pulled out to come home and knew something was wrong. only half block from house so i limped and screached home at about 2 m.p.h. this is what i foundever bend a tierod? Tie_ro10ever bend a tierod? Tie_ro11 i never saw one bend like that before. advance and autozone dont stock it. rock auto lists an inner and an outer. i need a passenger side/left. is that outer? was hoping to walk in somewhere and buy it but if i must order it, i at least want the right one.
    ever bend a tierod? Empty Re: ever bend a tierod?
    Post by jrinaman Fri Dec 02, 2011 4:38 am
    meant to put that in g van. can it be moved?
    Number of posts : 387
    Post by whopman Fri Dec 02, 2011 5:12 am
    i believe the only difference between right and left tie rod is the threading...one is right hand the other left hand..
    Post by whopman Fri Dec 02, 2011 5:17 am
    moog part numbers ES350L AND ES370R..see if your local store can do a cross reference search..
    Number of posts : 1778
    Post by m1dadio Fri Dec 02, 2011 7:32 am
    Mine were bent when I got the van.
    If an alignment shop uses a torch to heat up the threaded joint to make adjustment after they have been there for years, that can make then soft. Also there has been alot of cheep a$$ made in china crap around for longer then most people know.
    I didn't notice mine at first but after stareing at photos like this one I noticed looking straight down the tie rod you can see the end joint is not in line because it is bent. you have to click on the picture to se the whole thing.
    ever bend a tierod? Dscn0212
    M1D
    Number of posts : 12246
    Post by donivan65 Fri Dec 02, 2011 10:02 am
    The main thing is that they keep the wheels going straight, so IF you are going to drive with a bent tie rod or center link, you need to adjust it to make the wheels toe in 1/16"....
    Number of posts : 2067
    Post by sasktrini Fri Dec 02, 2011 11:07 am
    Quite the carnage!
    m1dadio, are you running with rack&pinion power steering?
    cculella
    cculella
    Number of posts : 111
    Post by cculella Fri Dec 02, 2011 2:06 pm
    Not to thread jack here, but I'm looking to tighten up my steering at highway speeds. Are the tie-rods a good place to start? Are there parts in this area that can get worn out and need to be replaced for better steering? I am not sure if this is just the way it is with these old van's steering setup or if it's something that can be tuned up to be tighter. Right now it can get to feeling like the van itself is drunk.
    Post by sasktrini Fri Dec 02, 2011 2:14 pm
    cculella wrote:Not to thread jack here, but I'm looking to tighten up my steering at highway speeds. Are the tie-rods a good place to start? Are there parts in this area that can get worn out and need to be replaced for better steering? I am not sure if this is just the way it is with these old van's steering setup or if it's something that can be tuned up to be tighter. Right now it can get to feeling like the van itself is drunk.
    The drag link between the steering gear and the knuckle... took a lot of slop out of mine! Plus I don't think they are made anymore, where tie rods have probably been replaced several times.
    Post by whopman Fri Dec 02, 2011 2:49 pm
    the drag link is still available...dang expensive though...i have found them from $192-350 bucks depending on which auto store you go to...oreilly gets theirs from rare parts $347...
    Post by whopman Fri Dec 02, 2011 2:54 pm
    cculella, tie rod ends are a good start, kingpins and bushings as well, then the drag link, then the steering box....there is an old thread on rebuilding the steering box...the rebuild is easy ...getting it out is a bit of a pain...also you have to find an old school front end shop that knows how to set up a straight front axle...
    cculella
    cculella
    Post by cculella Fri Dec 02, 2011 3:14 pm
    Post by donivan65 Fri Dec 02, 2011 3:28 pm
    The test would be for someone to rock the steering wheel back and forth,but not enough to move the tires,,,,while you look under the van at the pitman arm coming out of the steering box,,,see if it is moving,,,see if the drag link is moving,,,then tie rods,,,,the idea is that everything should be tight, no slop,,,everything is a connection,,,if one part is moving and the other part is not,,,,there is a problem there,,,,you are checking those 2 ball joints on the drag link as well as those 2 tie rods,,,,if the steering wheel rocks a lot and the pitman arm don't move,,,,that is a steering box problem,,,,and you also need to jack up the axle and rock each wheel in and out at the top and bottom to check the bearings and kingpin bushings,,,,
    Post by donivan65 Fri Dec 02, 2011 3:35 pm
    The pitman arm needs to come off for the drag link to come out,,,,Here is my video of a steering box,,,,
    ever bend a tierod? Th_steerboxvideo
    Post by whopman Fri Dec 02, 2011 3:51 pm
    I watch donivans video early this year and rebuilt my steering box, easy nothing was worn out...made a gasket out of gasket material and steering works great...what I discovered was the steering gear lube had gotten to the point it was like paste....probably the most overlooked maintenance part of our old vans....if you have the van manual it goes into detail on how to set the preload on the steering gear box..
    Thanks again donivan !
    Post by whopman Fri Dec 02, 2011 4:00 pm
    Post by donivan65 Fri Dec 02, 2011 5:04 pm
    whopman wrote:I watch donivans video early this year and rebuilt my steering box, easy nothing was worn out...made a gasket out of gasket material and steering works great...what I discovered was the steering gear lube had gotten to the point it was like paste....probably the most overlooked maintenance part of our old vans....if you have the van manual it goes into detail on how to set the preload on the steering gear box..
    I figure most people here ain't professional mechanics, so I don't quote the repair manuals,,,,go read them if you want,,,,I have had to read them all my life,,,,so what you see is actual repairs broken down in simple language from memory,,,,and I make up what I forget,,,,but my postings ain't too far off,,,,,,
    Post by m1dadio Fri Dec 02, 2011 10:40 pm
    just afew coments:
    You are talking about a suspention and steering system designed in or around 1796 by an American stage coach opperator and designer. But thats a history lesson we will avoid today. Two solid axles on four leafsprings, i mean come on can you get more primitive then that?The only real improvment on it in 2 hundred years is pnumatic tires.
    In order for these vans to drive rasonably well all the steering parts and the king pins need to be in excelent condition. More then that the wheel alignment needs to be correct. That can't be understated. if the alignment is out the van will act "Drunk" more then worn parts. You also need to look at the leaf springs and especialy the leaf spring bushings and shakles. Also bent parts need to be changed for straight parts, Yes you can adjust a bent tierod to correct the toe in and it will drive in a straight line but it will not steer correctly on turns as the inner and outer steering wheels will not be able to maintain their relative track angle to each other.
    My power steering is not Rack and pinion,it is a home design using the valve and assistance piston from a 69 Mercury Couger.There is a big post on it somewhere here.
    that is a good vidio, thank you Don
    M1D
      Current date/time is Fri Nov 22, 2024 5:38 am
