Broke a J bolt pulling the tank out, whats everyone doing bending one up out of allthread? Source for them? What about the rubber hose (tank to filler)? Thanks alot guys
J bolts, and rubber junk for the gas tank
Yes - tank to filler & maybe another for the venY/ overflow= yes u can use all thread - or a longer threaded bolt welded to the strap- remember all thread is avail in stronger grades also =Happy Vannin
[i]
[i]
Casimier- Number of posts : 864
If you need a 6" piece of the gas tank hose let me know.
I had to buy a 36" length from my local NAPA store.
It cost me $30...I'll cut you a piece free..just pay the freight. This way I'll feel better about paying too much.
Jim
Jim
Linoman- Number of posts : 329
I was able to buy 1 foot of the filler hose at Auto Zone, or maybe it was O'Rielys. But I bet Cashmiers offer would be cheaper.
Thanks for the heads up guys, Gonna run home after work and check it all out again and see what Im up against. Thanks alot Cashmiers I will post later on tonight about it. And see where we go from there.
A member here (Dennis) has stainless j bolts and straps
Thanks vanishing, would you happen to know how to get in touch with him? I searched under dennis but wasnt confident who it was. Going to give autozone a try on the filler hose and if they dont have it im going to get in touch with you casimier. Thanks for the help guys. Got to working on the dog house then couldnt access thru my phone for some reason last night.
dennis@dddiscbrakes.com He also makes a nice front disc brake kit and dual bowl master cylinder as well as several other things.
When I replaced mine I went to Home Depot and bought a couple of turnbuckles to replace the J bolts. Quick and easy
