+5
SteelyVan
66 G10
9 posters
door stays anyone try this rebuild
66 G10- Number of posts : 39
Registration date : 2010-11-25
SteelyVan- Number of posts : 112
Yes. I did choose to use the shorter arm that they came with. Plenty of swing (60ish degrees instead of 90) to get in and out with less risk of tagging someone parked beside you. I am disappointed that the spring mechanism that holds the doors open have gotten lazy after only 2 years. Probably made in China. I got them from LMC or Brothers. For people searching for these they are mostly referred-to as "door checks". I'd like to find a Made in USA or equivalent to OEM so we don't have to keep buying new or screwing around with re-tensioning the springs. I've got small arms so I can swap them out easy....bigger dudes probably not. If ya drop it......its fishin time in the deepest portion of the door!
m1dadio- Chevy Guru
- Number of posts : 1778
All the above are darn good improvments.
I like the idea of less door opening. I always have to be carfull opening the front doors in parking lots. I never realy liked the 90* door opening anywhere , theres just too much risk of the wind taking it or some one hitting it.
Dan do you have a part number for those jeep ones?
M1D
M1D
did they put these on the side and rear doors of our vans? i have cloth straps that prevent them from opening too far, but nothing to keep them from swinging back in. never took a second to look at the fronts (they work fine) but has to be a way to use this on the other doors. obviusly it would need to be more than 90 degrees.
jrinaman only on the front doors, Corvair vans have them on all of them
so has anyone installed them on side doors? i have only had van since march and came close to ripping the doors off a couple times.
Re: door stays anyone try this rebuild
It would be a nice mod for sure, never liked those straps
Thanks Donivan
I'm startin to think that if you had worked for NASA.......the Shuttles would still be flying!
,,,,,,thats 64Chevy guys job,,,,,,
I'm gonna try these new ones at some point. All the JY owners in my area
are REAL hard to deal with. I don't even go anymore. Last time I wanted to know how much for a pair of moldy, ripped, rusty spring sticking out Fiero seats?...... $300!..... and if you haggle, they get pissed.
$27 each????? well,,,,,,,I think these are kinda sorta included in the $2 entrance fee at Pick a Parts,,,,,
They do have a pair (no pins/brackets/nuts) for $39. My nearest Pick A Parts is a 2-3 hour drive. Daily driver is a Ford 250 Econoline (Triton). Round trip gas $30-$50.
,,,,,,I think we will just have to keep you in mind if we see a Cherokee,,,,(pop the pin up, remove the two 10 mm nuts off it,,,,pull the door panel back and reach in there and pick your part),,,,
Kakster- Number of posts : 236
- Post n°19
I had the wind grab the driver door from me durning a strong Santa Ana day and it broke the door stop and bent the body. Felt like a fool. I used a side (or rear) door strap to improvise a new door stop. Not as nice as the one discussed above but workable.
For a way to keep the side and rear doors open I have these wood post teathered close by.
- Post n°20
Thats a great Idea!!
gregw98- Number of posts : 31
- Post n°21
Did you know that you can get some black RIT Dye at Rite-Aid and boiled your door straps in it for about 5 minutes, and they look like new again.
