    b&m trans kickdown switch
    b&m trans kickdown switch Empty b&m trans kickdown switch
    Post by Twinpilot001 Sat May 14, 2011 2:22 pm
    http://www.bmracing.com/PRODUCTS/Transmission-Accessories-and-Kits/TH400-Kickdown-Switch
    This is what i have used for years -trouble free & easiest to install. Get one
    Number of posts : 277
    Registration date : 2011-01-20
    b&m trans kickdown switch Empty Re: b&m trans kickdown switch
    Post by Lyrad Sat May 14, 2011 5:48 pm
    Dude ..... that looks good. Do I just bolt that to my carb. and run a wire down to my tranny?
    Post by Twinpilot001 Sun May 15, 2011 6:58 am
    Yes - so easy it will surprise you & The directions come with it. Ive never had one fail in 35 years -installed many in rods & cars .Happy vanning
    Number of posts : 1651
    Post by Scott Sun May 15, 2011 8:35 am
    Hey Twinpilot,
    What types of Transmissions have you used this on, or have you only used it on the th400? Do you have a picture of one that's installed, or the directions that you can scan and post?
    Instead of wiring this through the brake I might try this one from B&M.
    b&m trans kickdown switch Bnm_lo10
    b&m trans kickdown switch Empty automatic trannys & some info & history
    Post by Twinpilot001 Sun May 15, 2011 9:11 am
    sorry I dont have any pics or info - email B&M - they will have it avail I do believe - also can search A1, rossi, and some of the older tranny builders for it & info. The switch is only for 400's and not any cable kickdown trannys = all the electric lickdown type solenoid trannys can use it. The one you have pic'd above is for the lockup type converters trannys - not on 400's. Also -to my limited knowledge -50 years now =most all lockup converters are changing to non-lockup types - just due to ease of conversion & operations. Or those that still want the lockup type and a better way to have the converter stay locked up=ie: saving fuel & performance . The B&M tranny group has been around since the late 50's and made their name in the early 60's building the (NOW) old GM 4 speed automatics ( B&M Hydro stick)- I acquired a new one in early 70's - a supercharged model and the literature with it stated - it was guarenteed for 100 full throttle runs - thats behind a Blown supercharged motor!! I even remember when "ED PINK" built blown hemis and when one was purchased he be there with the customer to tune it for the 1st 3 races!! Talk about customer service & satisfaction!!
      Current date/time is Sun Nov 17, 2024 5:28 pm
