    240 with auto choke carb linkage pics
    Number of posts : 864
    240 with auto choke carb linkage pics Empty 240 with auto choke carb linkage pics
    Post by Casimier Mon Apr 11, 2011 1:17 pm
    Anyone have a 240 with an auto choke carb....?
    Think you can send me some pics of how the throttle linkage hooks up and a couple pics of the idle screw linkage?
    The PO did a makeshift job on the 240 install....things just don't seem right...
    here's a pic of what I got.
    240 with auto choke carb linkage pics Engineswap009
    Number of posts : 2067
    240 with auto choke carb linkage pics Empty Re: 240 with auto choke carb linkage pics
    Post by sasktrini Mon Apr 11, 2011 1:32 pm
    Looks normal to me... Autolite 1100(?) carb. if you can take a pic from the backside for a better view of the choke assembly and throttle linkage... I don't actually have an autochoke, but might know enough to be dangerous. Also, an expert here may see if something is connected wrong or something.
    Cheers.
    Number of posts : 12254
    Post by donivan65 Mon Apr 11, 2011 3:53 pm
    240 with auto choke carb linkage pics Ford_l10
    Post by Casimier Tue Apr 12, 2011 5:18 am
    I'll have to take another pic from behind the carb..looking forward.
    But that does not help me because I know it is wrong.
    Each pic above shows two bracket assemblies..1st thing I see wrong with mine.
    I need to see the correct setup with a 240 automatic.
    Post by Casimier Mon Apr 25, 2011 6:44 am
    Hey Donivan
    Thanks for the pics....
    If you take a look at the figure above, I need the bracket assembly that gets bolted onto the intake manifold ...
    Braket assembly 99C765A or 9C795
    Lever Assembly 9C794
    Washer 351589-52
    Hir Pin 3S2358-57
    If anyone has these pieces ...please let me know
    Post by Casimier Mon Apr 25, 2011 11:08 am
    here is a pic of what I need...
    the bracket that attaches to the manifold holding the spring
    and the linkage going back to the throttle cable pin by Sasktrini's thumb knuckle
    240 with auto choke carb linkage pics IMG_04511
    Can anyone help me locate these pieces....???
    Number of posts : 2198
    Post by EconoUSAparts Mon Apr 25, 2011 6:15 pm
    I ve got the parts but Im so far behind right now due to all the rain I dont want to commit to you cuz it may take me a while. Im also scheduled 60 hours at work this week and next.
    Post by sasktrini Tue Apr 26, 2011 1:38 am
    The autolite carb was pretty common on these. I bet any 300 I6 would have those brackets... really just a return spring and link. If you go to a salvage yard, I would think you could find them in most any F150.
    The ball end on the lower arm is where the throttle cable attaches. Manual choke cable attaches to the upper through a bracket and pinched into the screw a couple inches above the ball. My guess is that the autochoke you have is in place of that upper part, and you are just missing the lower bracket and link. Good luck.
    Post by Casimier Tue Apr 26, 2011 7:45 am
    Yes you are right Corey..I need the lower bracket assembly and link
    Tim if you have the parts..I want them..please...need them to get the truck runnin good to make the Carlisle trip!
    I'll keep you guys posted if I get the parts from the salavage yard.
    Thanks Guys
    Post by sasktrini Wed Apr 27, 2011 2:10 pm
    oh hey, there is another web forum I joined to help me figure out the particulars of these old Big Ford Sixes (and the Small Falcon Sixes).
    FordSix
    Post by Casimier Sun May 01, 2011 12:14 pm
    so far so good...I bid on a 67 autolite carb on ebay and the guy took off the linkage setup off the manifold for me...If I win the auction I'll have the linkage...
    Tim , please still keep up the search...I'll still buy the one from you.
    Jim
      Current date/time is Sat Jan 18, 2025 8:22 pm
