    carb linkage
    matt_the_grouch
    Number of posts : 14
    Registration date : 2010-01-27
    carb linkage Empty carb linkage
    Post by matt_the_grouch Thu Jan 28, 2010 3:14 pm
    previous guy rigged up the throttle linkage and stuff is missing. im trying to get this all back to stock and im looking for some pictures so that i know what is missing. i know there is also a rod missing from the transmission. here is what the guy did. any pictures of what the stock set up would be greatly appreciated. thanks!
    carb linkage Chevy_16carb linkage Chevy_17carb linkage Chevy_18
    if you guys want any other photos just let me know.
    Number of posts : 1383
    carb linkage Empty Re: carb linkage
    Post by BILLS66 Thu Jan 28, 2010 5:19 pm
    Matt,I think I saw the pics of your van auto trans I assume don't know if these are the parts your looking for but pulled these off my 70 6cyl/auto parts van carb linkage stuff and some kind of rod that went to the trans. Bill
    carb linkage IMG_0863
    matt_the_grouch
    Post by matt_the_grouch Thu Jan 28, 2010 5:58 pm
    guess i should have said what year and what not. 65 sportvan with auto trans and its the 230 i believe from what ive read about the block numbers.
    Number of posts : 2632
    Post by savage Thu Jan 28, 2010 7:12 pm
    Bill what you want for the backup swicth??
    Number of posts : 12248
    Post by donivan65 Thu Jan 28, 2010 7:50 pm
    Well the gas pedal is hooked to the lower bellcrank on the inside of the doghouse by a long rod,,,then that bellcrank is hooked to the upper bellcrank that is on the intake manifold by another rod,,,,,,then that bellcrank is hooked to the carb linkage by another rod,,,,,
    carb linkage Thrott10
    matt_the_grouch
    Post by matt_the_grouch Thu Jan 28, 2010 9:21 pm
    thanks that diagram helps a lot! im not sure how he has the cable hooked up i will have to take a closer look tomorrow. did they use the same linkage on multiple years, say like some of the 2nd gen? or even later?
    Post by BILLS66 Fri Jan 29, 2010 6:25 am
    Savage,Nothing if you need it you can have it won't be much to ship. Bill
    Post by savage Fri Jan 29, 2010 8:46 am
    Thank's Bill Cool ,PM sent
    Post by BILLS66 Fri Jan 29, 2010 3:05 pm
    Tom back up swicht in the mail. Bill
    Post by savage Mon Feb 01, 2010 12:55 pm
    Bill got switch today ,Thank's again. Hope you get the $$ soon. Didn't work at frist ,but took it apart cleaned it up & lubed it, works like new now.
    Post by BILLS66 Mon Feb 01, 2010 1:20 pm
    savage thats great ,Was a little dirty wasn't it. Bill
      Current date/time is Mon Nov 25, 2024 4:02 pm
