Is it best to just cut it off?
door removal on Falcon 61 van
sunnskate- Number of posts : 120
Re: door removal on Falcon 61 van
The doors a off a part van I have
organ grinder- Number of posts : 149
Is there a reason why you can't unbolt them from the door jamb?
one thing you might want to consider is replacing all the hinge pins... that's one way to remove the doors anyway, without relocating the hinge bolt positions.
sunnskate wrote:Is it best to just cut it off?
Sunnskate, any way you can "scale down" the large pic of your van to a small avatar like the rest of us. Having it appear in every single post is confusing and also a space hog in a long thread with a lot of posts by you. You can post the arger pics in your showcase pics of your van.
Now to the doors, its easiest to just unbolt them. Sometimes the bottom hinges fight you a bit due to rusted bolts but an impact wrench usually cures that and shears the bolt off in the process. I do it all the time. Upper bolts generally come right out with an air ratchet.
Sorry Ill just stay away.
Big ass meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee.
its a supper van. Ill cut it down sorry guys.
Thanks for the parts EconoUSA they fit better.
gmp- Number of posts : 18
Registration date : 2011-01-06
sorry to thread jack but what size are the door pins and anyone know where i can pick up a few?
