by Digz Thu Mar 17, 2011 4:13 am
We ran into the same thing on my brothers 59 dodge truck, you can get the seals np, The numbers on the lower bearing that we could find actually cross to a bearing that doesnt work. On the truck there are needle bearings inside the section the worm gear rides against, these were worn and allowed that part to rock on the pin that goes thru it, overcame that by ditching the needle bearings and having a machine shop ream and make a bushing to replace them, that pin is staked in and somewhat difficult to remove, I havent seen a van box opened up yet was wondering if its the same way??
