Vanner63
    Wheel cross over
    Vanner63
    Vanner63
    Number of posts : 235
    Wheel cross over Empty Wheel cross over
    Post by Vanner63 Wed Mar 02, 2011 11:27 am
    Need some assistance concerning wheels. Someone told me that the wheels off a Ford Ranger or Mustang will fit our early Econoline's. Is this true and if it is does it matter what year Ranger or Mustang? Thanks ahead of time for your help.
    T.W. Day
    Number of posts : 575
    Wheel cross over Empty Re: Wheel cross over
    Post by austinmodhouse Wed Mar 02, 2011 11:39 am
    most will work. I got a cheap set of used mustang wheels with decent tires. look for 15 inch 5 lug ford wheels.
    Number of posts : 3046
    Post by RodStRace Wed Mar 02, 2011 11:59 am
    The bolt pattern is 5 lug on a 4.5 inch circle.
    AMC/Jeep, Older Mopars and Fords all share this pattern.
    One thing to watch for is the center hole, which can be a different size.
    The other common pattern is Chevy which is 5 on 4.75". Then you get into trucks (bigger) 6 and 8 lug patterns and the modern metric stuff.
    Mustangs up to 78, later ones are 4 lug until you get up to the late 80s when they went 5 lug metric.
    All this is online if you search.
    score602
    score602
    Number of posts : 140
    Registration date : 2010-04-05
    Post by score602 Thu Mar 03, 2011 5:29 pm
    any 94 and up mustang will work...79-93 were all 4 lug unless converted.
    Number of posts : 1422
    Post by Magic Bus Thu Mar 03, 2011 5:32 pm
    One set of aluminum ranger wheels I tried fit the bolt pattern but I would have had to install longer studs to get enough threads for safe attatchment....Just an FYI
    Number of posts : 2016
    Post by Barnabas Wed Mar 09, 2011 7:54 pm
    Ranger and Aerostar rims fit, but as Magic Bus said, aluminum rims are thicker then steel, so might require longer studs.
    Sixties through early seventies rims -- Maverick, Mustang, Fairlane, Falcon, Ranchero, Comet, Cougar, Marquis, and Montego.
      Current date/time is Sat Jan 25, 2025 1:33 pm
