    fixin floor pans
    fixin floor pans Empty fixin floor pans
    Post by Guest Mon Feb 28, 2011 8:12 pm
    is it a good idea to use bolts/rivets to fix holes on the floor?
    Number of posts : 12189
    fixin floor pans Empty Re: fixin floor pans
    Post by donivan65 Mon Feb 28, 2011 10:17 pm
    I think it's really up to you,,,,,you fix it the best way you can,,,,,,if thats sheet metal screws or pop rivets, fine,,,,,,if that is welding a new or replacement panel in, thats fine,,,,,just cut out the bad stuff, remove the rust, put some rust encapsulator on it and seal the seams. You can always go back and do it better later.......
      Current date/time is Tue Oct 03, 2023 9:39 am
