I need your help again. I need the front wheel cylinders for a 1969 G-20. anyone know where I can get them???
+4
GreyFoxMC
got2bowl
8 posters
Front wheel cylinders for a 1969 G 20
got2bowl- Number of posts : 55
Registration date : 2010-12-10
I need the whole thing and those look like they are for a G 10. they are different. everyone has a the G 10 cylinders but not the G20
GreyFoxMC- Number of posts : 56
Registration date : 2008-06-02
Not looking good.
Nobody is showing the front cylinders - 1 3/16ths bore.
Gm #'s are 5460329 & 5460330
These are for 67 - 70 G20 & G30
DanTheVanMan- Commissioner
- Number of posts : 7900
m1dadio- Chevy Guru
- Number of posts : 1778
You might consider a close match and modify the back plate to fit it in.
What did the 3rd gen use?
M1D
M1D
got2bowl,
Here are some readily available bolt-in replacement cylinders.
Only difference is they are 1 1/8" not 1 3/16" - should not make a big difference.
These cylinders are IDENTICAL in every which way except the bore size.
Raybestos , Wagner and Centric all use the same part number(s) for them : WC14493 & WC14494
You're welcome !
Jerry an old Corvette guy from Canada
You're welcome !
slowrider- Number of posts : 111
Registration date : 2011-07-15
how abought same year from a c-20,just a thought.
Scott- Number of posts : 1651
I don't dung about vans but why would "same year just C-20" work any better ?
What is the bore size, hose ftg size, hose angle , bolt pattern etc etc ??
They are either : the same - which means they still won't be available (same part number !) OR they may be "similar" BUT will be different.
What will be different will have to be determined (how and by who ?)
I KNOW that the ones I posted about are IDENTICAL except for bore - why "Richard around" trying to make something else work ?
FYI : the Raybestos kit number for the 1 3/16" cylinders is WK237
Im not saying that a c20 will be the same as i dont know the sizes ,i was just throwing out a possability.Ive only owned my van a short time but havent yet found any vendors that supply the complete line of parts that are available for old trucks.I was happy to get a master and front cylenders from orileys auto parts for my 65.The new front shoes however were to thick for the drums to turn even with the ajusters turned all the way out.
clayton stites- Number of posts : 7
Registration date : 2011-02-15
wheel cyl
look at www.usautoparts.net
The USA Autoparts site lists front ones from Raybestos, but according to the Raybestos site those are not for the G20, they fit a C20. They may work, but the Raybestos site doesn't list the bore size.
Raybestos does show that they make rebuild kits, but they don't list the bore size either.
The correct wheel cylinders ARE NOT AVAIALABLE ANYWHERE period !
No other parts chain, no other brake parts manufacturer has them, they are obsolete !
I have stated the known alternative : the rest is just "could try" "may work " but none of you KNOW that IT WILL WORK - just a bunch of guess's.
The guy has probably gone on to install disc brakes anyway LOL
