Hi. I have a '67 G20 108 van with solid I beam front axle.
I am wondering if it's ok to put the floor jack in the middle of the front axle and jack up the front of the vehicle that way, or if this will bend the front axle and cause problems. Then I would put jack stands on either side of the axle or on the "frame".
Meanwhile I'll just be using the jacking points on either side of the vehicle....
