    wheels, sizes and bolt patterns
    Slick Steve
    Slick Steve
    Number of posts : 38
    Registration date : 2010-06-08
    wheels, sizes and bolt patterns Empty wheels, sizes and bolt patterns
    Post by Slick Steve Thu Jun 17, 2010 5:49 pm
    I know, I know. FnG with a ton a questions here....
    What size wheels came on the econoline? What was the bnolt pattern? Im guessing 5 on 4.5??
    thanks!
    Optik
    Optik
    Number of posts : 25
    Registration date : 2010-06-15
    wheels, sizes and bolt patterns Empty Re: wheels, sizes and bolt patterns
    Post by Optik Thu Jun 17, 2010 8:14 pm
    bolt pattern should be standard Ford small pattern, 5 on 4.5". I would guess that original stock wheels were probably either 13" or 14", probably 4" or 5" wide.
    -Tim
    Number of posts : 3046
    Post by RodStRace Fri Jun 18, 2010 6:24 am
    Both the Dodge and the Ford are 5 lug, 4.5 inch circle. GMs are 5 on 4.75.
    As mentioned, they were skinny back when new, but wider will fit.
    With even little Toyotas and Kias having 15s stock, the available rubber for 13s and 14s is getting less and less.
    You also want to avoid all FWD wheels that have an offset that is not happy on RWD vehicles.
      Current date/time is Fri Nov 22, 2024 5:56 pm
