Hi what are the stock wheel sizes for a 1968 van and what is the bolt pattern (are they 5 on 4 3/4"?)the same as chevy because i havea friend who has a set of stock steel rims for a 59 chevy,Sorry for the questions as i just bought the van yesterday and it has a bad set of 8 spokes on it that need to go!
tikiwagon
bolt pattern and wheel sizes for 1968 van
tikiwagon- Number of posts : 55
Registration date : 2012-10-22
welcome to VV, the dodge axle is 5"x4.5", same as the old Ford axles. You can use a 14 or 15 inch rim but dont get radical with the back spacing, tire size also matters.
A 225x75x14 will fit, as will a 235x75x15 iirc.
Summit racing stocks some good looking rims in that bolt pattern still and you can find use rims on Craigslist pretty cheap sometimes.
Thanks is that size ford only not chevy?
Yes, 5x4.5 is a ford/dodge bolt pattern only. Some Jeeps run that same pattern as well. Chevy patterns are 5x4.75, or 5x5
You might want to take a closer look at tyour friends wheels... They commonly make some "multi pattern" wheels that are made to look like old stock wheels but have two different bolt patterns in them. You'll know these wheels because they will have probably 10 lug holes.
Or atleast I find them somewhat frequently on cars I pick up out here anyway.
I have been offered a set of 14" x 6 shod with 215-70-14 tyres that come from a coronet (including full size hubcaps) would they be 14" or 15" as a stock size?
- Number of posts : 8732
what year coronet would you be talking about.
The coronet 14X6" wheels should fit fine. The vans often came with 14" wheels and they should not be too wide or have too much offset to fit.
Rod is right. the van should be 14x 5 and in this case one in will make no differance. Althou some times it does, just ask my wife...
Thanks for that guess i will go for them!
