+50
VanninBlaino
mrclean
Bear
organ grinder
Rick's 66 Chevy Van
Oldsmobubble
Kris64
A100Sportsman
HOTRODVAN
Sebastien1988
GMC-BURB
badnova
sonnygable
mo_1040
Wookee
LiveWire64
Hangtime
gotavan
gp70
Hemi A-100
wacko
54 posters
Project "G"
- Post n°126
Re: Project "G"
G-Man, your gonna have to paint that van red if it keeps popin' wheelies like that!
- Post n°127
Re: Project "G"
funny you should say that , it is going to be RED Had to pick a color that Don would like.
- Post n°128
Re: Project "G"
I like red also! Bill
- Number of posts : 12245
- Post n°129
Re: Project "G"
Can't go wrong with red,,,,,,red does not seem to be too common of a color on all the vans that I have seen. I have seen more yellow ones out here.
- Post n°130
Re: Project "G"
most earlys ive seen usually white , turquise or blue. red does look good on a van, orange does too!
- Post n°131
Re: Project "G"
A little progress.....
So you get a better idea how I'm going to have a removable doghouse with a air tunnel these pictures will help explain that. There will be a lip on the front section that the back section will mount on.
Right now replacing that bad front section
And when I'm looking for something to do I have been cleaning 40 year old glue off the doghouse lid.
DanTheVanMan- Commissioner
- Number of posts : 7905
- Post n°132
Re: Project "G"
Wow Chris. You've been busy. Looks great. Nice clean looking tunnel, good job.
- Post n°134
Re: Project "G"
Yeah , that looks like it awta dress up nice! Are those 1st gen radiator supports I see? Just takin them out?
- Post n°135
Re: Project "G"
Digz they have been out, but part of them will be used for the new radiator mount. Here what I'm working on now. I'm making parts work together that don't go together. Using 1st & 2nd gen radiator mounts together with a 1st gen belly pan The new mount with help from the 1st gen mounts will make it removable. I will post pic's when it done. I can tell you this that the belly pan will have to see some changes so it will work.
- Post n°136
Re: Project "G"
Hey at least you have a belly pan to work with ! Sounds like a good plan, I like it when things can be unbolted to.
- Post n°137
Re: Project "G"
- Post n°138
Re: Project "G"
Got the radiator mount figured out, like I said earlier using 1st & 2nd gen mounts together. Cut down the 1st gen mounts for the room I needed, the new mount will mount will the 1st gen mounts to the frame like stock, but the 2nd gen mount will hold the radiator. Going to cut off the 2nd gen mounting tabs because they are not needed. This isn't done yet, but now making the side supports for the radiator.
- Post n°139
Re: Project "G"
It has been a good week on the 64. Got the welding that needed done finished. Used a great product for hidden rust and the whole undercarriage was sprayed with a Eastwood rust convertor. It leave a smooth surface on rusted areas also. (It looked like it was painted black) Very happy with it. This morning had to scuff the convertor before it was primed. Used a black apoxy primer that I am happy with also. Hoping to paint on Tuesday. Nice to see something go on this van instead of just taking stuff off.
- Post n°140
Re: Project "G"
- Post n°142
Re: Project "G"
Thats a lotta work ,, Looks great!
- Post n°144
Re: Project "G"
Chris,
Is that (POR15) your spraying? Sure does look nice......
- Post n°145
Re: Project "G"
Lookin great G . Gloss is Boss!
- Post n°146
Re: Project "G"
Dan it's a tinted apoxy primer. The stuff is hard as nails. The cataless has a smokie vapor when you open it. You can spray it on thick will no runs. Very happy with it.
- Post n°147
Re: Project "G"
Chris, I would love any info on the product. I like the sounds of it and plan on attacking the body on mine this spring. Mine has next to zero rust and think this may be what I am looking for to keep it that way.
Let me know,
Dan
Let me know,
Dan
- Post n°148
Re: Project "G"
We threw out the can, but I think I can try to dig it out of the trash. Do you have a Painter supply co. down your way???
- Post n°149
Re: Project "G"
Sure do... And a few old spray guns too. It looks just like POR15, I use a lot of it but have to brush it on due to it's thickness. Would love to be able to spray!!! The time that would save me!! Any info would help Chris....
Thanks,
Dan
Thanks,
Dan
- Post n°150
Re: Project "G"
Hello Chris - Van looks nice. I'm sure it will be a pleasure bolting stuff on while the bottom is clean. You might not have to wash your hands when your done!
