Disc brakes for A-100s
Re: Disc brakes for A-100s
Thanks for the link!!! I'm sure alot of "A" guy's have been looking for them.
Steve Scott in Ohio (he has the yellow SS/V A-van) make disc brake kit, but I don't know if he sells anything.
i talked to a guy had a 66 A pickup it had discs when he baught it ,he didnt know much about it other than it was a kit for a 68 road runner. ive looked around and the kits are expensive.
Hemi A-100- Number of posts : 255
Location : Somewhere between HELL River and London Ontario
Registration date : 2008-06-17
Wilwood doesn't have a kit but I used their parts to adapt their disc brakes onto my A-100. It was a bit expensive but well worth the money cause we all know brakes are the most MOST important.
I've never bought disc brakes to install on any of my A's, but then again I've never had anything other than stock engines.
I tell ya there is something to be said about having confidence in your brakes. Like I say I run Wilwoods on the front and SVO discs on the back and that truck of mine will stop on a dime.
savage- Number of posts : 2632
Yea but when you got a Hemi in your A you need them. You own one Sweet A -100
even with a stock 8 panic stops are scary was that truck ever at carlisle?did you buy it from Bob i dont remember it having a hemi- 383 if my memory is correct, but that was a few years ago i loved the color scheme- still do its a beautiful ride
What was involved with the SVO discs on the rear? Was it a tough swap? My A is factory 318 w/727 and I dont have much confidence in the brakes...I looked into the kit from AAJ Brakes but my problem is i have a factory sway bar and dont really want to remove it unless I have too? Anyone know of any other alternative The discs are a must as I have A 360 in the works...Rat
Thanks guys for the nice comments. Benwah, ya my truck was in Carlisle back in 1998. You are probably thinking of Bob Engel's black and white truck that had the 383 in it. That truck is now in Northern Ontario. My truck was total stocker when I bought it from him. Also when I bought it it was 1998 GMC colors which totally had to go cause they looked to "new" for the truck. The truck is now correct 1970 Mopar Deep Sherwood Met. I see if I can find a picture of the truck when it was down at Carlisle in 98.
The SVO disc brakes on the back were easy. When I was building the Dana for it I put on a set of Ford housing ends and the disc brakes bolt right to it. Actually the brakes are made by Team Strange but are a total copy of the SVO ones. On the front the Wilwoods I think are the way to go. I was able to put on aluminum hubs, vented brake rotors and billet Wilwood calipers on it the straight axle and man those things STOP!!! All I had to do was machine the one side of the face of the spindle to accept the Wilwood caliper braket. I have a factory sway bar on the front of my truck too.
seemed like Bob had a diffrent truck every year at carlisle for a while!
Ya, he has had the black and white pro streeter that he built. He had the red truck that use to belong the John Graham which Wayne Taylor owns now. Then he sold both of those. Then he had my truck down there in 1998. Now he has the pro streeter that Roy Haire built with the Hemi in it. Which is now for sale.
Hey Hemi thanks for the info I would like to talk to you more about the willwood swap...is that A kit or did you have to piece it togather? Where did the caliper bracket come from? I was wondering if possible to get your email addy I need to get some stopping power before I go any further and would like to purchase some wheels also Thanks..Rat I just looked back at the forum and seen it was not a kit but still wondering where did the caliper bracs come from to clear the sway bar? U make them?
Hey 57ratrod, the caliper bracket came right from Wilwood. You will have to machine the face where the old backing plate bolted onto. Nothing major, just the width of the actual bracket. I will get the part number off the braket for you. I wanna say it was a A body bracket... but it has been 10 years since I did that. Also you might have to machine a ring to put into the braket hat depending on which you decide to run to space it out a bit. With mine I had to to run the vented rotors my buddy's shop sells. I also added aluminum hubs too. If you are not in a huge rush I usually every winter take the front end somewhat apart just to check everything. This winter I could take a pile of pics of my set up. Let me know. Also my email address is theace27@hotmail.com
I have a brake sticking on the pass side front that needs attention..im going to prob put a new set of shoes on for now so i can get a little bit of fun safe drive time before winter then tackle the disc setup over the winter so that would be perfecto!!! Where did you find the aluminum hubs what were they off of? Did they require mods to put them on,and also was wondering if you were able to keep the same bolt pattern for wheels sake or did you have to buy diff bolt patt wheels? I got ur email addy thanks I may drop u a line for some tech tips...THANKS so much for the help..Rat
Hey Rat, the aluminum hubs are ones that my buddy's company builds for Team Strange. He just matched up the bearing races from the original hubs. You can get the hubs in whatever bolt pattern you want. I ended going with a 4 3/4 bolt pattern cause my dad has a Mailbu he races so that way we can switch wheels back and fourth if we want.
Here is a link to the SVO brakes I use on the back of my A-100.
http://www.bearsperformanceproducts.com/index.php?main_page=product_info&cPath=4_101&products_id=173
Here is a link to the front brakes I run, except I run Wilwood calipers instead of the Strange ones shown which basically look the same.
http://www.bearsperformanceproducts.com/index.php?main_page=product_info&cPath=4_28&products_id=244
- Post n°19
What is the name of your buddies company? sounds like you got this whole brake thing down to a science, I cant wait to get the brakes fixed on my van...its pretty sweet if I am wanting to make a right hand turn,just apply the brakes and let go of the wheel..LOL my goal is to update enough so i will be able to make road trips and drive daily in nice weather without worrying bout if im gonna be able to stop at the next town or light. Dont get me wrong everything works just not as well as I like my brakes to work,but the van is 40 years old and shes doin the best that she can,she just needs a little TLC.
- Post n°20
sorry bout the double entry
- Post n°21
Bears Performance is the name of the company.
- Post n°22
Thanks again Hemi I was just lookin at ur ride in the gallery and gotta say...DYNOMITE!!!! One sweet ride
- Post n°23
Thanks very much Rat, always nice to hear that.
