by Old Skool Wed Mar 10, 2010 6:40 am
Early pins have the large donout o-rings. (61-->63). The 64-->67's shorter in length, same diameter, with the screw in caps top and bottom, zirc fittings in the caps. Earlys had two zirc fittings, one in each bushing on each end of the spindle.
Early and late bushings can be interchanged, only problem there, is if you use a early bushing in a late spindle, make sure you have th grease slots in the correct position to allow the grease to enter from the caped end with the zirc fitting, the early bushings greased from the diamond shaped hole in the center of them.
In 42 years, I have NEVER seen a plastic bushing for ours??? they could not hold up??? Also, there is NO such thing as an oversized (.010) pin for the lates, HOWEVER,,, YOU CAN MAKE ONE out of an early pin, as it is longer. Simply cut the donut o-rings ends off and match to length the late pin. If the pin "IS LOOSE AND OR WOBBLES" in the axle, you are pretty much SOL. One option is a truck repair place in San Diego, that specializes in truck straight axles. They know how to bend them correctlty for caster, and also, can "KNURL" the axle in order for the pin to fit snugly. Its very difficcult, and very expensive to "SLEEVE" a worn out axle, and usually better to find one in good condition? or try to use the oversized pins.
Having owned a machine shop, I will only have my bushings honed on a Sunnen type hone for this. I had a complete set of adjustable reamers to do the job also, however the hone is on the money with no gauging and or low spots. FAR more accurtate of a job.
Personally, also made a press fixture with a bottle jack, that presses the pins out of the axle on the truck, so I can avoid taking the whole axle out?? doesn't work all the time though, as some are just more stubborn than I... LOL... rosebud and and the press and still won't budge...
ALL axles themselves are the same from 61-->67, however the difference is in the spindles themselves with the caps of early donout o rings. Spindles are identical to each other also, and can be interchanged from side to side, IF you can get the steering arm off. There are two different height steering arms also, of different yrs, and bump steer geometry.
vic
