+6
ChevyVanMan1
joyrde
10 posters
    '67 GMC drivers door hinge
    joyrde
    joyrde
    Number of posts : 26
    Registration date : 2009-03-12
    '67 GMC drivers door hinge Empty '67 GMC drivers door hinge
    Post by joyrde Sun Jan 24, 2010 12:14 pm
    I may need to replace my driver's side upper & lower hinges. I could weld them and re-drill the holes, but I would rather "just" re-pin the hinges.
    Anyone have a set or just the upper for sale???
    joyrde@mail.ohio.net
    '67 GMC drivers door hinge Empty Re: '67 GMC drivers door hinge
    Post by G-Man Sun Jan 24, 2010 12:34 pm
    joyrde PM Danthevanman he will be parting one out soon
    Number of posts : 1383
    Post by BILLS66 Sun Jan 24, 2010 1:20 pm
    John,You have email. Bill
    '67 GMC drivers door hinge IMG_0862
    Post by G-Man Sun Jan 24, 2010 2:08 pm
    sorry Bill I forgot you had parts also
    Post by BILLS66 Sun Jan 24, 2010 2:37 pm
    G-Man it's all good I was just kinda snickering at myself when joyride posted I had no idea I had the hinges laying on my work bench right in front of me!I think I need to clean up my garage a little.It's not real dirty but some van things laying around. Bill
    Number of posts : 12246
    Post by donivan65 Sun Jan 24, 2010 3:16 pm
    ,,,,,or rebuild the old ones,,,,,,,,,
    '67 GMC drivers door hinge Hinge_10
    Post by Guest Mon Jan 25, 2010 10:28 am
    Joyride, I have a box full of door hinges. I'm in Northest Ohio. If you drive over, you can have a driver's door hinge ass'y. I'm in Lake County. kenclem@rocketmail.com
    Post by G-Man Tue Jan 26, 2010 3:20 pm
    Don will this pin kit also work on side doors????
    Number of posts : 7905
    Post by DanTheVanMan Tue Jan 26, 2010 4:48 pm
    G-Man wrote:Don will this pin kit also work on side doors????
    Chris, it worked on all mine. Of course that was last summer when I couldn't find any hinges. Now I have enough spares to go all the way around (Twice).....
    Dan
    '67 GMC drivers door hinge Qr_cod10
    Post by G-Man Tue Jan 26, 2010 5:32 pm
    Thanks Dan!!!!
    Post by donivan65 Tue Jan 26, 2010 6:33 pm
    They actually work just right for the side and rear door hinges. Since the front door hinges are a little thinner than the side ones, you might want to trim a little off the end of the pin after it is installed if you don't like how it looks. And its a good idea to replace the front hinge pins and bushings to prevent those cracks around the hinges, vent glass and latch from those heavy doors jumping around from worn out hinges.
    Post by G-Man Tue Jan 26, 2010 7:54 pm
    Thanks Don I kind of figured that were the same because you never said they were differant in the other posts you have made on this very same subject, but thought I should ask.
    ChevyVanMan1
    Number of posts : 425
    Post by ChevyVanMan1 Thu Feb 17, 2011 11:08 am
    Stupidly I bought one of those hinge pin removal, C-clamp tools via BobDrake.com (a Ford restoration vendor). Could not have been a bigger PITA. The included ram sheared, the threads weren't right on the bolt either and the tool is a $30 paper weight. Anyway, contacted Bob Drake for refund and just get a littany of crap about how hard it is to be an American company reselling what appears to be Chinese c**p.
    Might have to R&R the hinges too--was looking for the easier softer way. Yet, I can assure you that is not to be had at Bob Drake.
    If anybody finds a well made type of door hinge pin removal tool I'd appreciate a heads up. Thanks and happy motoring!
    Post by Twinpilot001 Thu Feb 17, 2011 11:14 am
    there is a great tool - called a torch & punch & hammer - ive done all mine & easy once u do one
    Post by donivan65 Thu Feb 17, 2011 12:19 pm
    Most of them will come out if you heat the 2 outer ends of the hinge with at least a propane torch and use a punch to knock the pin out,,,,,I would surely heat it up ,,,,,,because,,,,,,you only get 1 good hit ,,,,if it don't move, you will mushroom it and have more work ahead of you,,,,,,
    '67 GMC drivers door hinge Repair36
    Post by Digz Thu Feb 17, 2011 3:05 pm
    You can also take a thin hacksaw and seperate the hinge to make a smaller bite.
    ChevyVanMan1
    Post by ChevyVanMan1 Fri Feb 18, 2011 8:55 am
    Thanks, I'll try those. Was just trying to keep it all on the van so I don't have to readjust the door or repaint.
    Oh yeah, latest response from Bob Drake "customer service" was that their tools are not made in China--they are made in Taiwan. Had to give them a little geography lesson. Amazing argument really.
    Much appreciate the help and TGIF
    66twodoorwagon
    Number of posts : 7
    Registration date : 2011-02-02
    Post by 66twodoorwagon Fri Feb 18, 2011 3:10 pm
    I rebuilt my hinges from the hardware store . The nylon busings were 16 cents a piece and the pins were 33 cents a piece. I used longer bushings than the originals so the pin had more surface to move on. I had to oversize the bushing hole to clean that hole up to recieve the new bushings without any force The hardware store also had brass or bronze bushings but I figured the van had the plastic bushings for 44 years the first time around so it should be good for another 44 years with a little tlc Ken
    Post by donivan65 Fri Feb 18, 2011 3:37 pm
    I guess if you want to remove the pins without removing the hinges from the van,,,,,you would need the Donivan 6500 hinge pin remover tool,,,,,,,
    '67 GMC drivers door hinge Repair37
    64chevy
    64chevy
    Number of posts : 364
    Post by 64chevy Fri Feb 18, 2011 4:01 pm
    You going to be selling those at the Big 3 next weekend?
    Post by donivan65 Fri Feb 18, 2011 4:19 pm
    Don't laugh, Joey,,,,,you never know what the next fad is,,,,,,,anyways,,,that Ball Joint Tool came in handy removing those Ford springs off Vanishes' van last week,,,,,,That tool actually is one of my best tools,,,,,,,it has all kinds of adapters to push and pull and nothing stops it when you use an impact to turn it,,,,,,
    ChevyVanMan1
    Post by ChevyVanMan1 Mon Feb 21, 2011 9:02 am
    Wow, what a big tool you have!
      Current date/time is Mon Nov 18, 2024 5:32 am
