mcfly
kgdb
    E100 Gas Tank
    kgdb
    kgdb
    Number of posts : 266
    Registration date : 2009-12-03
    E100 Gas Tank Empty E100 Gas Tank
    Post by kgdb Mon Dec 14, 2009 6:20 pm
    My fuel tank has a few small holes that I thought I would just weld up and then get the tank lined. Is there another preferred fuel tank that you guys use when our stock tanks go south? Just curious.....
    kgdb
    E100 Gas Tank Empty Re: E100 Gas Tank
    Post by G-Man Mon Dec 14, 2009 7:04 pm
    Try doing a search on the subject, I kind of remember someone talking about a mustang tank
    kgdb
    kgdb
    Post by kgdb Mon Dec 14, 2009 7:18 pm
    G-Man wrote:Try doing a search on the subject, I kind of remember someone talking about a mustang tank
    Thanks. If I remember correctly the mustang tanks are all rear center fillers. No problem to move the filler and vent if need be but if I can find something closer would be groovy. A fast check and it looks like a ford full size van tank (75-77) may just do the trick. Thanks
    kgdb
    Post by Guest Mon Dec 14, 2009 7:53 pm
    kgdb wrote:My fuel tank has a few small holes that I thought I would just weld up and then get the tank lined. Is there another preferred fuel tank that you guys use when our stock tanks go south? Just curious.....
    kgdb
    I usually have one made out of aluminum. I also have it made to hold 20 gallons. I think the last one cost me $200.00 to have made.
    kgdb
    kgdb
    Post by kgdb Mon Dec 14, 2009 7:58 pm
    kgdb[/quote] I usually have one made out of aluminum. I also have it made to hold 20 gallons. I think the last one cost me $200.00 to have made.[/quote]
    Thats doable but what do you do for a sending unit? Thanks
    kgdb
    mcfly
    mcfly
    Number of posts : 626
    Post by mcfly Mon Dec 14, 2009 8:13 pm
    kgdb wrote:Thanks. If I remember correctly the mustang tanks are all rear center fillers. No problem to move the filler and vent if need be but if I can find something closer would be groovy. kgdb
    Thats what I did. You also are going to need a new fuel sending unit that goes with the new tank. Mustang tanks hold more fuel so they are alittle bigger because of this I made new straps.You also have to do a little cutting and bending of the flange.It's very important to get the filler in the right spot not alot of play in the angle.
    E100 Gas Tank Dsc04812
    mike
    Number of posts : 2198
    Post by EconoUSAparts Mon Dec 14, 2009 8:17 pm
    69 Mustang tank is what a lot of us use. Install the original vent and filler from the Econo tank into the same location as stock for Econo but on the Mustang tank,then plug off the Mustang fill location and you're good to go. Use the stock Mustang sending unit.
    fmc56
    fmc56
    Number of posts : 553
    Post by fmc56 Tue Dec 15, 2009 12:22 am
    Here's one I did using a 69 Mustang tank. I TIG welded mine but have done several by silver soldering them, which is the way they were originally done.
    https://s225.photobucket.com/albums/dd187/fmc56/Econolines/20%20gallon%20fuel%20tank/
    http://mysite.verizon.net/vzeuu09l/id3.html
    Fred
    kgdb
    kgdb
    Post by kgdb Tue Dec 15, 2009 4:41 am
    Thanks for the info guys. Will look for a Mustang tank.
    kgdb
    RobSWD
    RobSWD
    Number of posts : 52
    Registration date : 2010-02-04
    Post by RobSWD Fri Feb 05, 2010 7:59 am
    Does the tank hang down real far in the back with the Mustang tank? My tank is pretty nasty inside, LOTS of chunks falling off the sides. Look great on the outside, but it's falling apart inside. Not sure if I should have it cleaned and get the stuff to coat it or upgrade to the Mustang tank.
    Post by EconoUSAparts Fri Feb 05, 2010 7:20 pm
    The 69 Mustang tank will hang about 2 inches lower than the stock one so you would need longer straps.
    Bluelemon
    Bluelemon
    Number of posts : 139
    Registration date : 2008-07-10
    Post by Bluelemon Fri Feb 12, 2010 6:46 pm
    For the cost of repair to your old tank, it may me better to start new. Ebay and Mustangs Unlimited sell new tanks with sender.
    May be able to find someone close to you with a good used one. Can't ship used ones with fumes.
    Post by Guest Sun Feb 14, 2010 5:59 am
    I bought my '69 Mustang gas tank for $99.79 and the sending unit for $42.79. I bought them from RockAuto.com.
    If I knew before hand that there was a cast iron weight above the tank, I would have removed the weight and had a 30 gallon tank made.
    Post by EconoUSAparts Sun Feb 14, 2010 3:38 pm
    The space the weight occupies is needed for the vent so you cant go upward into that area with a bigger tank. The weight has a hollow portion to allow for the vent. There are other tank choices besides the 69. Jim Bulger can comment on the one he used in his.
    Post by Guest Sun Feb 14, 2010 5:00 pm
    I had the vent put on the top of my tank and had the inlet relocated to the stock location but the vent doesn't need to be on the top. It can be routed just like it is on the '69 Mustang tank. The tank doesn't know it's in a van. The weight I took out of my van doesn't have a hollow portion. It's as solid as can be. I would still opt for the larger tank.
    Post by Guest Sat Apr 10, 2010 8:47 pm
    Hi Mike... do you have to cut out the frame support in front of the tank in order to get 20 gals?
    Post by Guest Sat Apr 10, 2010 8:53 pm
    txdennis wrote:Hi Mike... do you have to cut out the frame support in front of the tank in order to get 20 gals?
    No. I take my old tank in and they just make a deeper one and keep all the other dimensions the same. Just have to make new straps.
      Current date/time is Sat May 11, 2024 4:58 pm
