    Replacement for the bushings on the accelorator pedal ..... 64-70
    Replacement for the bushings on the accelorator pedal ..... 64-70 Empty Replacement for the bushings on the accelorator pedal ..... 64-70
    Post by Vanish Fri Oct 16, 2009 7:03 pm
    replacement for the bushings on the accelorator pedal
    http://www.corvette-paragon.com/p-351189-accelerator-rod-pedal-pivot-bushing.aspx
    Replacement for the bushings on the accelorator pedal ..... 64-70 3731K
    OR ................ Gas Pedal Bushings (2 req) GM # 3710620
    Still available as of last year at your local dealer (2008)
      Current date/time is Mon May 06, 2024 10:06 pm
